New Game "Cacorm" by Inufuto
Rich
Post by Rich »
Another Game from Inufuto 2/7/2022
You can clear the level by drawing a line all around the stars.Avoid the monsters.
Download link from his site ,scroll down to the vic-1001
http://inufuto.web.fc2.com/8bit/cacorm/#vic
nbla000
Salmon Run
Re: New Game "Cacorm" by Inufuto
Post by nbla000 »
Nice game vaguely inspired by Mr Do Run Run, does Inufuto is a Denial Member?
Just for fun, starting from the tap version, I've released a prg version to use it also from a disk drive or SD2IEC device, no SYS command required, just LOAD and RUN.
Like the original inufuto tap file, Vic+16k is required.
Cacorm 16k.zip
(7.43 KiB) Downloaded 90 times
Thank you Nicola, much appreciated 👍
necronom
Occupation: IT Support
Post by necronom »
Thanks, nbla000, I was playing this a couple of days ago. I got to level 10 which I think is the last one. I like it.
And orion70, I was playing Sorcery earlier, so I know where your avatar is from now :-)
