Vic20 programming languages online?
I am looking for some Vic20-based programming utilities online. I am aware of UPL and Datatronic Forth. Are there any others?
- AndyH
- Occupation: Developer
Re: Vic20 programming languages online?
There is WAX which is a modern extension to BASIC and it gives you an assembler, disassembler and the ability to write and mix assembler code in with your BASIC amongst other things.
https://github-wiki-see.page/m/Chysn/VI ... 2-Tutorial
I downloaded it. Thank you.
- Occupation: Engineer
Human Engineered Software (HES) also released a Forth cartridge, confusingly also called VIC Forth. The also released Turtle Graphics i.e. Logo, though that is stretching the definition of a programming environment rather a lot. If you are looking for a cross development system, look up Turbo Rascal (no, that's not a typo)
Note that if you plan to use the Datatronics VIC Forth, unless you are using the original cartridge you need to have a 3K RAM cartridge installed (or configured in an emulator) as the cartridge includes 3K and assumes that memory is there.
