Do you have both a Mega-Cart and a uIEC/SD2IEC drive?
nbla000
Salmon Run
Post by nbla000 »
Good!
I'm releasing a new ADDON for any Mega-Cart revision that by using an external SD drive allows to play all new, next coming rev.22 items.
There are many kind of Vic-20 setups and a lot of sd2iec firmware based devices, I've tested many combinations but If you have one that I've not tested, it could be useful if you may help me with some test.
I need to know Mega-Cart revision, SD drive type (SD2IEC/uIEC/etc), Vic-20 model (PAL/NTSC/PRONG/CR) and if you have other classic drives (with or without JiffyDOS).
To know which revision you have, just press [F3 Info] from the first mega-cart menu, if there is no revision info than you have an early revision.
So if you want to help me, just contact me in PM providing your setup and cross your fingers, if you are lucky, you may receive a preview of the ADDON :P
rhurst
Omega Star Commander
Occupation: Tech & Innovation
Re: Do you have both a Mega-Cart and a uIEC/SD2IEC drive?
Post by rhurst »
Any update on its progress or clues with its features?
