I've been playing Robin Hood today and once I worked out that Block 5 needs to be write protected I could get past screen one, but on the third time I got to screen two the gate doesn't open. I tried again and the same thing happened. It makes the 'level complete' noise, the people stop appearing and the arrows start shooting across the doorway, but the gate is down and it kills me on contact.
Is this a known bug, should it be opening, or am I doing something wrong?
Here is a video of it happening:
https://youtu.be/Ec08GJD7bJo
Robin Hood
Re: Robin Hood
By using the zimmers version, I've discovered it has a ram protection on $A535
To fix this protection, use this command before the reset.
POKE42295,192
It changes the code in this way:
Since I wasn't able to go to the next level, I've discovered also a way to have infinite lives.
and Infinite arrows:
But the problem still remain...
So I've tried it in ROM but with same results, so or it is a bug of the original game or a bad dump.
Istruction attached.
a533 A2 00 LDX #$00
a535 8E 65 A6 STX $A665 <---- BLK5, error if work in RAM not protected.
a538 CA DEX
a539 86 1D STX $1D
POKE42295,192
a533 A2 00 LDX #$00
a535 8E 65 C0 STX $C065 <---- Basic vectors in ROM, no problem.
a538 CA DEX
a539 86 1D STX $1D
POKE42049,165
POKE42513,165
POKE43232,165
POKE41827,165
- necronom
- Occupation: IT Support
Re: Robin Hood
Thanks for taking a look. I'd tried it several times and got to the problem gate most attempts, but it always got stuck.
I wonder if it's a bad dump, like you said. I'd be surprised if it shipped like that, as it only took me about 3 goes to get that far. Someone must have played it before it was sent off to be manufactured!
