TRIANGULAR μOS 1.11-1.19 for VIC-20 in BASIC
Re: TRIANGULAR 1.10beta2 for VIC-20 DOWNLOAD
TRIANGULAR OS wrote: Mon Apr 25, 2022 6:39 am BTW, anyone where to get screen memory start and color memory start in VIC-I graphic chip registers? Right know I have simple mechanism implemented to determine where screen memory starts: PRINT {cursor down} + character and if peek one of 2 locations (4096/$1000 or 7680/$1E00) )
Screen memory page is $0288 for start of character memory. And then
lda $0288
and #$03  ; This came from the KERNAL disassembly around $ea77
ora #$94
the result will be the color memory page. In other words...
SM = PEEK(648) * 256
CM = ((PEEK(648) AND 3) + 148) * 256
TRIANGULAR OS
Website: https://www.youtube.com/@triangular_uos
Post by TRIANGULAR OS »
chysn: thanks. Very useful.
TRIANGULAR μOS for VIC-20:
http://www.sleepingelephant.com/ipw-web ... =2&t=10352
TRIANGULAR μOS YouTube channel:
TRIANGULAR OS
Re: TRIANGULAR OS 1.10beta3 for VIC-20 DOWNLOAD
OMG, it's nearly a month from my last reply and I promised release within a week. :shock: Sorry for that, but my own things plus sunny weather = very small amount of time for this project recently + I was a little stuck in experimenting with WORDS worprocessor formula.
TRIANGULAR OS 1.10Beta3 for VIC-20 is ready to release.
What's new:
- Various bugfixes and improvements across the board
- TRIANGULAR OS launching program improved
- BIOS small visual changed
- GUI program instead of DESKTOP. THIS PC renamed to THIS VIC.
- SETTINGS run from icon on desktop open folder with into two apps:
1. SYSTEM which can change time, work disk and printer options
2. COLORS can change background colors and patterns.
- WORDS instead of old WORD is completely overhauled
- MATH calculator improved: user can input numbers from keyboard
- 1 new game: REMEMBER 20. Try to recreate sound tune by pressing key 1-4. This is 10 liner created by Rainer Kappler (Masterware Entertainment).
PREVIEW (YouTube):
DOWNLOAD (Beta3):
TRIANGULAR OS 1.10beta3 VIC-20.zip
(14.37 KiB) Downloaded 95 times
Planned for future beta4:
- Further improvements and bugfixes
- Add sound Synthesizer program
- Add some additional games
TRIANGULAR OS
Re: TRIANGULAR OS 1.10beta4 for VIC-20 DOWNLOAD
TRIANGULAR OS 1.10Beta4 for VIC-20 release:
What's new:
- DISK program bug in start menu handling fixed
- MATH calculator: removed A <> B register swap
- SYNTH added synthesizer program for VIC. F5 & F6 vol down and up. F1-F4 Select one of VIC voices. Press keys to play. Space for elongate sound.
- 1 new game: Need for VIC. Racing game by Fabrizio Caruso. Controls: J and L keys
PREVIEW (YouTube):
DOWNLOAD (Beta4):
TRIANGULAR OS 1.10beta4 VIC-20.zip
(16.1 KiB) Downloaded 106 times
Nice! Congratulations on this. I have seen the video, and wonder if - for the sake of speed - one could jump directly from an app to the desktop, without loading back the apps group again (e.g., when you're done playing with Need for Vic, F7 or ESC brings back the desktop directly). Would this be too difficult to implement in a future release?
TRIANGULAR OS
orion70 wrote: Thu May 19, 2022 11:10 pm Nice! Congratulations on this. I have seen the video, and wonder if - for the sake of speed - one could jump directly from an app to the desktop, without loading back the apps group again (e.g., when you're done playing with Need for Vic, F7 or ESC brings back the desktop directly). Would this be too difficult to implement in a future release?
Thanks for great suggestion. That can be done very easy. I will change F8 to F7 for exit app. F8 (or Shift+F7 on real machines) will go to DESKTOP. Off course it will only work in non-windowed apps, since windowed ones can go back directly to desktop by clicking on Start Menu/Desktop.
My plans for near future: I will have to enhance WORDS app (it's still in works). Improve current 2 games and add 2 new. And probably will change REMEMBER 20 for something more aspiring. Plus will try to convert my STAR WARS shooter from PET (I'm stuck with it somewhere in the middle of conversion from 40 to 22 column display). And after some general improvement, debugging, finetuning I will be able to release full version of TRIANGULAR OS 1.10 for Commodore VIC-20 5KB. I would like to finish this version before summer (somewhere in June).
My long term plans: I won't be gradually converting it to ML, as originally planned. First I will convert it to C64 (still BASIC version) in original form (as it is right now). Then I will try to consolidate it into few bigger files, add sprite mouse cursor, sprite TIRANGULAR start menu orb, custom fonts, maybe add turboloader. I would like to finish converting + consolidating C64 BASIC version during this summer.
And from there either convert OS core (BIOS + GUI) to ML or better go straight forward for cartridge version (more advanced ML version). Cart version seems very tempting, especially for VIC-20 (especially, because it can run on lowest 5KB machine). We will see.
Last edited by TRIANGULAR OS on Thu May 26, 2022 4:16 pm, edited 7 times in total.
cobracon
Post by cobracon »
I'm really digging this new program. I think it would be cool to put on a cart once its done. Would make it work like a real os gui. Would really be cool if we could use a mouse on a vic-20. Don't know if a mouse would even work? I have a mouSTer (think thats what its called) that can emulate a 1351 commodore mouse. Keep up the great work.
Yep a kind of Magic Desk I for the VIC - but impossible to fit in a cart being a multi-load, multi-app packet, isn't it?
orion70 wrote:Yep a kind of Magic Desk I for the VIC - but impossible to fit in a cart being a multi-load, multi-app packet, isn't it?
It is perfectly possible to provide a CBM DOS like file system on cartridge. Kananga did this with the FE3 RAM Disk for read and write access; write-only, non-volatile file data could be held on (EP)ROMs.
Yep this would be nice, but maybe a bit expensive.. I was thinking about MCes' Jolly Cart, which for that purpose wouldn't fit.
orion70 wrote:[...] which for that purpose wouldn't fit.
Such a read-only resource file system is implemented in about 1 KB of code plus whatever is the combined size of the files contained in the "ROM disk" plus a bit of extra info, like file names, file position and size info.
A cartridge with banked memory areas (like FE3 is) is not a pre-requisite for this, a simple unbanked memory card with 32K ROM could hold at least 8 files/programs for the unexpanded VIC-20 this way.
I see - my question now is (and the answer would be very informative and didactic here Mike :) ), would these programs / files be able to "talk" to one another, i.e., load one another, get back to desktop, etc?
Please pardon my ignorance in the matter :mrgreen:
orion70 wrote:[...] would these programs / files be able to "talk" to one another, i.e., load one another, get back to desktop, etc? [...]
That is exactly the point of providing the data as files in a file system, opposed to just being memory blobs located somewhere in the cartridge ROM: the former allows to access the files via LOAD (from BASIC or KERNAL, regardless), the latter would require raw access via memory transfer routines in machine language (and thus present a non-standard interface to user programs).
The file system driver actually encapsulates those memory transfer routines, so programs have no idea they're not running from disk or tape, but rather a cartridge based "ROM drive".
TRIANGULAR OS
Update: Beta5 work in progress.
So far I've added 2 new games. Currently working on 3rd game, which will replace Remember 20. Although I originally planned more than 4 games, I will stick with this number. I will have to improve them.
Next will try to improve WORDS, minor improvement of SYNTH and make some minimal visual changes to GUI. Also I'm planning to alter loading screen, precisely to change hourglass to something smaller (hourglass seems to be too big, out of proportions). I will submit proposals later. And that will be Beta5.
Then Beta5 will be improved & debugged. After that either I will release RC (release candidate) or Beta6 (if debugging will go slowly). First RC0, then RC1 and after everything will be OK will add some protective measures like make disable upper/lower char, disable run/stop, revert loading messages back to black etc.
As for cart version, I would like to put on cart only OS core. That is: BIOS, GUI with system folders, SETTINGS, DISK. Rest of system (apps, games) will be on system disk. I have question about that. Cart OS will be ML, but can some apps be in BASIC (I don't know if I want to for example convert games to ML)?
Last edited by TRIANGULAR OS on Sun Jun 12, 2022 11:51 am, edited 2 times in total.
TRIANGULAR OS wrote:Next will try to improve WORDS, [...]
When one enters a single text line, and then scrolls up and down a few times, WORDS crashes with an ?OUT OF MEMORY error. Doing a ?FRE(0) reveals there are still some 900 bytes free, so this crash is likely due to mismatched GOSUBs filling up the stack.
More info:
viewtopic.php?t=10195&start=6&hilit=GOSUB
viewtopic.php?t=10252&start=21&hilit=GOSUB
This is a category of errors that better should not be permanently fixed into a cartridge ROM ...
Edit: also the boot procedure immediately stops in VICE, when True Drive Emulation is off and VICE accesses the disk image with VDrive. Your boot loader tries to determine the disk drive type with a M-R command, which likely returns some unexpected value here. Unfortunately, you did not guard ASC() by concatenating CHR$(0) to the read-in character - GET# errorneous reads in CHR$(0) as an empty string, ASC() doesn't like this, therefore something like:
GET#...,A$:A=ASC(A$+CHR$(0))
... is the way to go here.
