cartconv
cartconv
This invocation claims that the conversion is successful:
/Applications/vice-x86-64-gtk3-3.6.2-dev-r41706/bin/cartconv -t vic20 -i file.prg -o file.crt -p
But when I "attach cartridge image..." in VICE, the memory at $A000 isn't changed at all. I've tried it with Block 5 RAM on and Block 5 RAM off. What's the correct way to convert a PRG file into a CRT file, and then use the CRT file in VICE?
Update: I set the "CRT" checkbox at the bottom of the window and it didn't do anything but bring up a bunch of settings.
Update: Oh! "Cathode Ray Tube!" Never mind. But I still have the CaRTridge problem.
Re: cartconv
What does this utility actually do (or meant to)? Relocate code to a new address and add a $a000 autostart header?
Re: cartconv
I don't think it will relocate, that's a job requiring hand-crafting.
Re: cartconv
AndyH wrote: Wed Mar 09, 2022 4:47 am What does this utility actually do (or meant to)? Relocate code to a new address and add a $a000 autostart header?
People have asked for a CRT image of wAx, which is 8K in block 5 with no autostart. So I'm trying to construct pretty much exactly what's in block 5, but as a CRT file instead of a PRG file. Nothing needs to be added nor relocated.
In other words, I think I'm struggling with the simplest-possible cartconv use case. As far as I can tell, that cartconv command should take the PRG file at block 5 and turn it into a CRT for block 5. -t means the cartridge type (vic20), and -p means "pad the code to 8192 bytes".
Re: cartconv
OK! You must be the first user besides me :=)
first, after you converted, you can use the -f option to see what the .crt actually contains, like
$ cartconv -f 0-generic-6000-a000-JungleHunt.crt
CRT Version: 2.0 (VIC20 CARTRIDGE)
Hardware ID: 0 (Generic VIC20 Cartridge)
Hardware Revision: 0
offset  sig  type  bank start size  chunklen
$000040 CHIP ROM   #000 $6000 $2000 $2010
$002050 CHIP ROM   #000 $a000 $2000 $2010
total banks: 2 size: $004000
i suspect it used a different start address (i dont remember what it uses by default if no address is given).
Now when the address is wrong there are two things you can do: a) use .prg files with load address in the first two bytes. I find that the easiest myself. or b) use the -l option to set the address.
If the address is actually correct and the file contains what it should contain (you may also look at it with a hexeditor, or convert the crt back to prg and then compare) then something in the vic20 cartridge mounting code is wrong.
It would also be cool if you could attach that binary - apparently in my testcases directory i dont have any cartridge that lives at A000 (only) at all - there is a chance i screwed something up somewhere and didnt notice :)
Re: cartconv
Thanks! The first two bytes of the PRG file are 00,a0, but I get this:
Name: Generic VIC20 Cartridge
$000040 CHIP ROM   #000 $0000 $2000 $2010
total banks: 1 size: $002000
When I do this command:
/Applications/vice-x86-64-gtk3-3.6.2-dev-r41706/bin/cartconv -t vic20 -i wax2.prg -o wax2.crt -p -l a000
The output of -f is exactly the same... So I don't seem to be able to set the start address properly...
Binary: https://github.com/Chysn/VIC20-wAx2/blo ... c/wax2.eep
Re: cartconv
Okay, got it!
(1) It doesn't work with PRG files. The two-byte address header was actually being used in the CRT code. Instead of using the PRG file, I used the binary EEPROM file.
(2) -l needs a base-10 address (40960) rather than a hex address (a000)
With those changes, I got a functioning CRT file.
Thanks!
Re: cartconv
it does - i think the trap you were falling into was that your prg file wasnt 0x2000+2 bytes - if you use the padding option, cartconv cant determine if this is prg file. i should perhaps emit a warning in this case
try 0xa000 - that should work :)
When you are done, could you post the file? I'd still add it to my testcases
Re: cartconv
groepaz wrote: Wed Mar 09, 2022 12:54 pm > It doesn't work with PRG files.
Oh! Okay. I'd prefer to build CRT images from binary files, anyway, and be explicit with the starting address. It seems much cleaner that way. I think PRG should be a cul-de-sac.
Which file, the CRT image? That's here in the repo now, along with the other build products: https://github.com/Chysn/VIC20-wAx2/tree/main/vic
Re: cartconv
Thanks, added to my testfiles :)
Re: cartconv
groepaz wrote: Wed Mar 09, 2022 4:20 pm Thanks, added to my testfiles :)
Thanks for your help!
