/* emulate Final Expansion v3.2 Super ROM write bug */
/*#define FE3_2_SUPER_ROM_BUG*/
I think it refers some discrepancy in whether writes go to bank 0 or 1 in Super ROM mode but I can't find any further details.
I'd like to understand this better before I write too much code that assumes the behaviour described in the original manual (which states writes go to bank 1).
srowe wrote: ↑Thu Dec 09, 2021 2:19 am
I'm playing around with code to use the various modes of the FE3 and noticed the following in the VICE code base
I wrote that code. It refers to a bug in the preliminary CPLD for v3.2 which I found when reverse engineering the CUPL code to implement emulation of the cartridge. This bug is AFAIK not present in any released v3.2 CPLD versions.
tlr wrote: ↑Mon Dec 13, 2021 1:04 pm
Thanks for the confirmation, I noticed this is commented out so there's no way to build VICE with it. I'm amazed that all the behaviour of FE3 seems to be so faithfully implemented in VICE. A lot easier to debug with than the real thing.
Thanks, I guess.
I had the CUPL source to work from, but there was also a decent test program by Thomas Winkler to run on the vic20 to verify the bulk of the functionality.
