User Port Emulation in VICE
Is it possible to simulate incoming data on VIA#1 Port B in VICE?
lda #%00000000
sta $9112 ; DDR - Input on all
sta $911c ; PCR - Interrupt input mode
The interrupt flag bit 3 is set when there's a transition on the VIA's CB2. But there's no memory that's mapped to this pin, the signal needs to go directly into the VIA. And it doesn't appear that I can "fake out" the code by setting the interrupt flag register.
I don't see anything promising in the VICE menus, so I suspect it can't emulate hardware at the granularity that I'm looking for. I want to make sure I'm not missing anything, though. It's no problem using real hardware. I just can't do it while sitting on the couch watching Star Trek.
Re: User Port Emulation in VICE
You'd have to hack in a userport device that does what you want to do
that said, the entire userport system is being rewritten right now - perhaps make a feature request that explains what you want to do, so we can think about some kind of interface for that
groepaz wrote: Sat Sep 11, 2021 5:25 am You'd have to hack in a userport device that does what you want to do
Thanks! My perspective on it might be a bit narrow, but I'll put some thought into how to phrase such a feature request. The question is, "what sets the simulated user port (a.k.a. VIA) pins high or low?" It would have to involve some communication between not-VICE and VICE. Back in my Amiga days I would have said, "This looks like a job for AAREX!"
One way could be:
- add a monitor command for it
- add a remote monitor command for it
