Hyperlinked Kernel Disassembly
I've taken the ROM disassembly from zimmers and via Notepad++ regex magic added some hyper-links that may help in browsing it.
http://www.fox-ts.co.uk/shared/vic20kernelrom.html
Since HTML doesn't support TABS some of the alignment is less than perfect.
Re: Hyperlinked Kernel Disassembly
Woah! Where were you like eight hours ago?!
Never mind, this is going to be awesome, thanks!
Would you consider basing off my revised listing? I've done an number of corrections and expanded some areas (including the tape code).
https://eden.mose.org.uk/gitweb/?p=rom- ... kernal.asm
sure, I'll take a look...
@srowe - sorry, I wasn't able to process your file as the you have updated some of the labels to have more meaningful description (which is good), but this stifles my simple pattern matching.
I have updated the original link to look a little better though.
