Using XOR to invert only 1 bit?
Victim_RLSH
Occupation: Machine Shop Lackey
Post by Victim_RLSH »
Here is code that reverses a ball velocity after it bounces off of something on its left or right side. I flip the sign bit of a 7-bit signed integer stored in one byte.
TestLeft LDA CollisionFlags
AND #FromLeft$
BNE TestRight
LDA BallXVel
AND #%01111111 ; remove sign bit to reverse X direction
STA BallXVel
TestRight LDA CollisionFlags
AND #FromRight$
BNE CollisionUpdate
LDA BallXVel
ORA #%10000000 ; add sign bit to reverse X direction
STA BallXVel
Would it be possible to use XOR to just invert the sign bit and not waste memory on both routines?
would XOR #%10000000 flip only the sign bit and preserve the absolute value?
Works in Progress: Gravity Ball, a breakout variant in assembly for the unexpanded vic-20
Re: Using XOR to invert only 1 bit?
eor #%10000000
will, in fact, do what you say, flipping bit 7.
But keep in mind that’s different than changing the sign.
%10000001 is not -1, %11111111 is. If you simply flip bit 7 of 1, you get -127.
That may or may not matter in your application. If you think it might matter, we can delve into signed binary numbers and twos complement arithmetic.
Hi, Victim_RLSH,
Of course you can do sign-magnitude arithmetic on the 65xx, but that's not how the ADC and SBC instructions are supposed to be used. 'Emulating' sign-magnitude will easily lead to ten times more code and one tenth of the speed than what you'd get by employing 2s-complement, because you have to do all kinds of tests and case selections depending on the signs of the arguments and operator (add or subtract).
I had translated the "BALLPING" program in the User's Guide some time ago for my ML/VICMON primer, you find it here:
viewtopic.php?t=9197&start=1
In the original BASIC program, the velocity inversion at the borders happens in lines 120 and 140, with DX=-DX and DY=-DY, respectively. This is translated into machine code as follows:
SEC
LDA #$00
SBC $xx   ; $xx=$F9 for DX, =$FA for DY
STA $xx
If the value is already in the accumulator, then it is a little bit shorter (3 or 2 instructions):
SEC ; can be omitted if it is known that C=1
EOR #$FF
ADC #$00
*or*
CLC ; can be omitted if it is known that C=0
EOR #$FF
ADC #$01
Note the equivalents of X=X+DX and Y=Y+DY simply use the ADC instruction with no case selections necessary (that would depend on the sign of DX or DY).
Victim_RLSH
Yeah, I did it the long way in this case, so the XOR should work. I just test for the sign bit and have separate increment and decrement routines depending on the velocity. No wonder I'm running out of space on such a simple game. My pathetic 6502 skills definitely need some help, which is why I'm doing this to begin with.
tlr
Post by tlr »
Victim_RLSH wrote: Tue Aug 03, 2021 6:15 am Yeah, I did it the long way in this case, so the XOR should work. I just test for the sign bit and have separate increment and decrement routines depending on the velocity. No wonder I'm running out of space on such a simple game. My pathetic 6502 skills definitely need some help, which is why I'm doing this to begin with.
Practise, practise. I can recommend disassembling other peoples code figure out how stuff is done. Coding assembly is a fun puzzle game!
tlr wrote: Tue Aug 03, 2021 10:45 am Practise, practise. I can recommend disassembling other peoples code figure out how stuff is done. Coding assembly is a fun puzzle game!
+1, you will learn some neat tricks which can save you space and/or clock cycles.
