I put this in the programming thread because while it looks like it is initially a C64 demo, it is probably equally feasible on a Vic20 as it is executed by the disk drive which both could use.
I am not usually a fan of demos but this one is really quite impressive and definitely worth watching the video.
https://hackaday.com/2021/07/08/c64-demo-no-c64/
An unusual demo that the Vic20 could also probably initiate
Re: An unusual demo that the Vic20 could also probably initiate
That's impressive.
For somebody who's been into Commodore stuff since 1980, it might be surprising that I've never once owned a Commodore floppy drive. Even when I had a C64, I was almost (save for floppy drives at school) entirely committed to tape. It's not like my parents wouldn't have bought me one for Christmas, or that I couldn't have saved up my allowance. It just never was something I thought about.
I realize that the 1541 has a 6502 and at least one 6522. I didn't know that it had enough RAM to do this kind of stuff, or that it had a mechanism to start executing code. Now I'm thinking it might be fun to pick up a 1541 and mess about with it.
Actually, that setup - with computer and intelligent drives as we see with CBM 8-bitters and 1541 drives - is much more akin to a computer network than what other contemporary computers got with their peripherals.chysn wrote:I realize that the 1541 has a 6502 and at least one 6522. I didn't know that it had enough RAM to do this kind of stuff, or that it had a mechanism to start executing code.
However, you must have been really quite aloof of this topic if it only appeared to you in the present time, with this example, that the IEC drives are actually computers on their own. The drives were not only reprogrammed in their RAM to install code for fast serial protocols, they also found use as co-processor to accelerate the computation of fractals, for example.
Of course it is entirely possible to port the loader to the VIC-20. But what does it buy you? If you follow the discussion in the C64 demo scene, even though the demo gets lots of praise regarding the idea, it is questioned whether it is a C64 demo at all. After the first code has been loaded into the drive, it is completely autonomous and loads the following parts into itself with a track loader that also runs entirely within the drive. It is really a 1541 demo. Porting the loader to the VIC-20 adds nothing to the actual feat done.Vic20-Ian wrote:[...] probably equally feasible on a Vic20 [...]
In fact, the CBM drives provide a way to load a file from disk directly into their RAM and execute it there. This is possible with those files typed USR, and it is only necessary to send "&filename" over the command channel to the drive. Then the demo would run from any 8-bit CBM that could otherwise use it as 'normal' peripheral.
"Of course it is entirely possible to port the loader to the VIC-20. But what does it buy you?"
I thought it would intrigue Vic20 only users (I rarely use a C64) who might want to explore this.
Yes it is a 1541 or drive demo but if my post served to get a Vic20 only user interested then it may inspire something else equally impressive.
Haven't checked the code here but if it doesn't use it already you could port it to use the 1541 utility loader function. That way a single '&' command to the drive could start it. Very portable. IIRC there is at least one 1541 DOS version that supports booting such a disk automatically when having the IEC-port pins tied in a certain way during reset.
ATM, the demo uses a PRG file to run on the C64 that inits the drive.tlr wrote:Haven't checked the code here but if it doesn't use it already you could port it to use the 1541 utility loader function. [...]
Maybe you could tell Matthias over CSDb about this? I tried to reach out to him via e-mail regarding that same idea, but my e-mail got bounced.
That feature was present in the 1540 DOS and very early 1541 DOS versions, but it got removed with later revisions as it led to an error blink status of the drive when the IEC signals provoked that drive boot procedure, but the seeked-for utility file did not exist:IIRC there is at least one 1541 DOS version that supports booting such a disk automatically when having the IEC-port pins tied in a certain way during reset.
... the utility file needs to be of CBM file type USR, and these files happen to feature a checksum - both of which are very unlikely to find on most disks.ftp.zimmers.net wrote:1541-e000.901229-03.bin
The firmware of an old-style 1541 with long board. This ROM has an autobooting feature: if CLK and DATA are held low during bootup, the drive will wait for them to raise, and execute a "&*" command.
