Your Computer (UK) - Type In, Millipods
One of the programs missing from http://www.vic20listings.freeolamail.co ... rcomp.html is "Millipods" from the March 1984 edition. The printout has a number of ambiguous characters, I don't believe anyone has ever got it to work before.
After repeated checks I resorted to disassembling the code and I've fixed a typo which seems to give a working program.
This attachment contains a .tap file with the original two parts as well as the main program which can be loaded and run with
LOAD"MILLIPODS.PRG",8,1
SYS6410
millipods.zip
(22.62 KiB) Downloaded 39 times
Re: Your Computer (UK) - Type In, Millipods
Post by Vic20-Ian »
Not a bad version. Thanks Simon.
A little sluggish on the shooting but quite playable.
