Comparing memory to find a changing value
necronom
Occupation: IT Support
Post by necronom »
I'm playing Saturn Caves (I like it and want to put a full playthrough on YouTube), and I get to the end and it seems to suggest that I didn't do it right. There is also a collectable and other exit that is inaccessible. I don't know what to do (I've read the instructions) so wondered if I can at least jump to the other side of the wall to confirm that the exit is real. I have a new version of VICE and an older one, and tried the monitor in both. The older one shows the memory, but it's in a long thin list that I can't copy and the new version doesn't seem to have anything like that.
I just want to compare between now and after I move right one square so I can add 2 to the value.
Of course, if anyone knows what I'm missing in the game, then that would do, too.
Noizer
Re: Comparing memory to find a changing value
Post by Noizer »
If something is wrong with the game, try posting here:
viewtopic.php?f=10&t=10013
necronom
Post by necronom »
Thanks, I didn't spot that.
