Preview: cbmshell, an interactive file processor
I've been developing a general-purpose utility called cbmshell that allows you to manipulate files within disk images. Think of it as a combination of c1541 and petcat but much more open-ended.
It's written in Python so should run on any platform, available from PyPI
https://pypi.org/project/cbmshell/
Documentation available here:
https://cbmshell.readthedocs.io/en/latest/
It's currently alpha quality, please back up any valuable image before trying it out. I plan to keep extending it, next feature will be to also support tape images.
Feedback welcome.
[edit: readthedocs link now live]
Re: Preview: cbmshell, an interactive file processor
I might not have a sufficient Python version, but I'll check it out if I can.
macOS Big Sur has 2.7.16, which seems new enough as far as 2.7 goes, but maybe not new enough for pip. But I'm no Python expert, so I'm not sure.
chysn wrote: Sun Mar 21, 2021 4:45 pm I might not have a sufficient Python version, but I'll check it out if I can.
I should have said it requires Python3, Looks like Big Sur includes both Python 2&3.
https://apple.stackexchange.com/questio ... n-for-good
I'd appreciate the feedback if it does work on MacOS.
Latest version now has support for .tap images in read-only mode. You can copy from tape images to disk images and/or the local filesystem.
I've been steadily adding features and fixing bugs to the point I'm going to declare it "Done" (i.e. it satisfies all my needs). It now supports read/write to all disk formats that I'm aware of (except GEOS), read/write to .tap files and read only of T64 and PC64 files.
I'm still open to suggestions for improvements.
make ran successfully under Big Sur. I had to do
sudo -H make
to avoid macOS complaining about directory privileges.
On the first invocation of cbm-shell, it advised that I needed to install gnureadline, which I was able to do with
sudo pip3 install gnureadline
And now, when I invoke cbm-shell:
$ cbm-shell
Traceback (most recent call last):
  File "/usr/local/bin/cbm-shell", line 6, in <module>
    from cbm_shell.scripts.cbm_shell import main
  File "/Library/Python/3.8/site-packages/cbm_shell/scripts/cbm_shell.py", line 10, in <module>
    from cmd2.utils import basic_complete
ImportError: cannot import name 'basic_complete' from 'cmd2.utils' (/Library/Python/3.8/site-packages/cmd2/utils.py)
My Python 3 version is 3.8.2. Am I missing another dependency?
chysn wrote: Sat Jul 03, 2021 6:59 pm My Python 3 version is 3.8.2. Am I missing another dependency?
No, I think it's a compatibility issue with the latest version of the cmd2 module (not one of mine). As a work around for now try
pip3 install --upgrade 'cmd2<2'
I'll look to fix this properly.
[Edit] Rather than installing this as root (and potentially messing something up) try using a virtualenv. They isolate package installation away from the system.
I've fixed the compatibility issues and released a new version (1.3) that should work with either versions of cmd2.
Yes! I've got a prompt! I'll be playing around with this tomorrow. I've got a stupid Independence Day party to go to today.
Okay, it's not stupid, it's with my wife's friends. But it would be rude to bring my Mac along.
Thank you!
Is there a way to take a standalone PRG file and put it into a newly-created TAP image?
chysn wrote: Sun Jul 04, 2021 10:06 am Is there a way to take a standalone PRG file and put it into a newly-created TAP image?
Hum, I thought I'd tested just that but there's a glitch working with an empty TAP file. Just repeat the copy command for now
(venv) [srowe@gilraen Downloads]$ cbm-shell
(cbm) attach new.tap
Attached new.tap to 0
(cbm) copy dungeon.prg 0:DUNGEON
EXCEPTION of type 'FileNotFoundError' occurred with message: [Errno 2] No such file or directory: 'new.tap'
To enable full traceback, run the following command: 'set debug true'
Copying dungeon.prg to ImagePath(0:b'DUNGEON')
(cbm) $
0 <TAP image>
15   "DUNGEON"          PRG
(cbm) quit
srowe wrote: Sun Jul 04, 2021 12:56 pm Hum, I thought I'd tested just that but there's a glitch working with an empty TAP file. Just repeat the copy command for now
Yep, that's the exception I was getting, and the second copy works as expected. Thanks again, this is awesome!
Enormous-ass feature request: A built-in disassembler to complement list!
chysn wrote: Sun Jul 04, 2021 10:15 pm Enormous-ass feature request: A built-in disassembler to complement list!
I hadn't thought of that but it would be straightforward enough to do. The main limitation would be handling blocks of embedded data, but that's the same as any simple disassembler.
Post by Vic20-Ian »
Great idea. Will you enter it into the Vic20 things we want to see / hear competition too? Closes November 30th.
srowe wrote: Mon Jul 05, 2021 1:20 am
I was going to amend my request to "If I were to write a 6502 disassembler in Python 3, could you integrate it?'
And, yeah, data's always going to be an issue. That's the way it goes.
