Preview: cbmshell, an interactive file processor
Re: Preview: cbmshell, an interactive file processor
chysn wrote: Fri Aug 13, 2021 7:08 pm Is there a limitation of the TAP format that prevents it from having multiple files with the same filename?
Nope, you can write two files with the same name. When you want to read them the first is named FILE, the second one FILE~1 etc.
I get this error when using a filename that's already in the TAP file:
EXCEPTION of type 'TypeError' occurred with message: open() got an unexpected keyword argument 'record_len'
So the question is, is this a bug in cbm-shell, or is that something the TAP format disallows?
That's a plain bug, which should be fixed in version 1.5, can you do
pip install --upgrade cbmshell
(or pull the latest code) and try again?
Thanks for being so responsive with this!
Is there a way to tell which version of cbmshell I'm on? pip3 indicated this:
Requirement already up-to-date: cbmshell in /Library/Python/3.8/site-packages (1.5)
But still
JEJ:vic jasonjustian$ cbm-shell
(cbm) attach test.tap
Attached test.tap to 0
(cbm) copy --type PRG easy.mod 0:EASY.MOD
Copying easy.mod to ImagePath(0:b'EASY.MOD')
To enable full traceback, run the following command: 'set debug true'
I'm not sure I entirely trust that pip3 is looking in /usr/bin/cbmshell. I've previously used the makefile.
chysn wrote: Sat Aug 14, 2021 7:08 am Is there a way to tell which version of cbmshell I'm on? pip3 indicated this:
You can use pip show cbmshell to tell you what's installed.
I'm seeing the same error, I'll investigate.
OK, thanks. Yes, I am on 1.5.
At the moment, I'm unable to copy from a TAP file to the local file system. I think I had that working before. I'm trying to build a process for moving from VICE to real tape, which is turning out to be a fun project. I've already got the process for going the other way.
Note that the tap file here was originally created and populated by cbmshell.
(cbm) $
0 <TAP image>
1    "DISASTER.MOD"     PRG
(cbm) copy 0:DISASTER.MOD disaster.mod
Copying ImagePath(0:b'DISASTER.MOD') to disaster.mod
Traceback (most recent call last):
  File "/Library/Python/3.8/site-packages/cmd2/cmd2.py", line 2330, in onecmd_plus_hooks
    stop = self.onecmd(statement, add_to_history=add_to_history)
  File "/Library/Python/3.8/site-packages/cmd2/cmd2.py", line 2781, in onecmd
    stop = func(statement)
  File "/Library/Python/3.8/site-packages/cmd2/decorators.py", line 379, in cmd_wrapper
    return func(*args_list, **kwargs)  # type: ignore[call-arg]
  File "/Library/Python/3.8/site-packages/cbm_shell/scripts/cbm_shell.py", line 314, in do_copy
    with dest.open('wb', ftype=ftype, record_len=src.record_len) as out_file:
AttributeError: 'TapImagePathRead' object has no attribute 'record_len'
EXCEPTION of type 'AttributeError' occurred with message: 'TapImagePathRead' object has no attribute 'record_len'
OK, this should be fixed in 1.6 which I've just released. It required a re-design of how TAP files are handled so there still might be some sharp edges.
Hmm, under 1.6 it's about the same.
JEJ:modpack jasonjustian$ cbm-shell
(cbm) attach disaster.tap
Attached disaster.tap to 0
(cbm) $
0 <TAP image>
EXCEPTION of type 'AttributeError' occurred with message: 'TapImagePath' object has no attribute 'record_len'
(cbm) set debug true
debug - was: False
now: True
AttributeError: 'TapImagePath' object has no attribute 'record_len'
(cbm) quit
JEJ:vic jasonjustian$ pip3 show cbmshell
Version: 1.6
Summary: Interactive shell to manipulate Commodore files
Home-page: https://eden.mose.org.uk/gitweb/?p=python-cbmshell.git
Author: Simon Rowe
Author-email: srowe@mose.org.uk
License: UNKNOWN
Requires: cmd2, cbmcodecs2, tapfile, cbmfiles, d64, t64
Required-by:
Doh, you're copying out of an image, I was doing the other way around.
[Edit] Try 1.7 which I've just released.
srowe wrote: Sun Aug 15, 2021 9:12 am Doh, you're copying out of an image, I was doing the other way around.
Yep, it's copying in both directions now.
The FILENAME~2, etc., doesn't work if there are more than one file with the same name. But I can make sure that won't come up too often. It looks like the really important stuff is good. Thanks!
chysn wrote: Sun Aug 15, 2021 3:15 pm The FILENAME~2, etc., doesn't work if there are more than one file with the same name.
Can you give an example?
(venv) [srowe@gilraen python-cbmshell (master)]$ rm -f new.tap ; cbm-shell 'attach new.tap'
Attached new.tap to 0
(cbm) copy short.prg 0:FILE
Copying short.prg to ImagePath(0:b'FILE')
(cbm) copy short.prg 0:FILE~2
(cbm) copy long.prg 0:FILE
Copying long.prg to ImagePath(0:b'FILE')
(cbm) $
0 <TAP image>
1    "FILE"             PRG
1    "FILE"             PRG
1    "FILE"             PRG
19   "FILE"             PRG
(cbm) $
0 <TAP image>
1    "FILE"             PRG
1    "FILE"             PRG
1    "FILE"             PRG
19   "FILE"             PRG
(cbm) list 0:FILE~2 | wc -l
1
(cbm) list 0:FILE~3 | wc -l
100
UPDATE: I had an aha moment, please see the post after the next
Huh. Here's what I'm trying to do:
(cbm) attach zeptopolis.tap
Attached zeptopolis.tap to 0
(cbm) $
0 <TAP image>
3    "2068"             PRG_RELOC
3    "2068"             PRG_RELOC
3    "2069"             PRG_RELOC
3    "2070"             PRG_RELOC
3    "2070"             PRG
(cbm) copy 0:2069 2069
Copying ImagePath(0:b'2069') to 2069
(cbm) copy 0:2070~1 2070.1
Copying ImagePath(0:b'2070') to 2070.1
(cbm) copy 0:2070~2 2070.2
EXCEPTION of type 'FileNotFoundError' occurred with message: File not found: b'2070~2'
(cbm) list 0:2070~2
File not found, ImagePath(0:b'2070')
(cbm) list 0:2068~2
File not found, ImagePath(0:b'2068')
(cbm) list 0:2068~1
$1e00:  10 11 12 13 14 15 21 21 21 21 21 21 21 21 16 17
$1e10:  18 19 1a 1b 1c 1d 3a 36 34 21 21 21 3b 32 33 39
    * * * etc. * * *
$1fe0:  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
$1ff0:  20 20 20 20 20 20 20 06 ff 00 14 08 ef 00 0b 09
(cbm) quit
JEJ:tap jasonjustian$ pip3 show cbmshell
Version: 1.7
Author: Simon Rowe
License: UNKNOWN
Requires: cbmfiles, d64, cbmcodecs2, cmd2, t64, tapfile
Required-by:
I think I misunderstood how it works.
FILE is the first, FILE~1 is the second, FILE~2 is the third, etc. I thought FILE~1 was the first. I think it's good!
Correct, it sort of makes sense I think. It's slightly different with the empty filename handling where the first instance is ~, the second ~1 etc.
https://cbmshell.readthedocs.io/en/late ... fname.html
srowe wrote: Mon Aug 16, 2021 6:23 am Correct, it sort of makes sense I think. It's slightly different with the empty filename handling where the first instance is ~, the second ~1 etc.
Again, I appreciate your responsiveness on this. cbmshell is an excellent resource, and it's become an important part of my scripted build process.
chysn wrote: Mon Aug 16, 2021 8:25 am Again, I appreciate your responsiveness on this. cbmshell is an excellent resource, and it's become an important part of my scripted build process.
Glad it's proving useful, the whole purpose of it was to remove the need for messy scripts joining together the existing tools.
mathom
Occupation: Software Engineer
Post by mathom »
I am probably missing something obvious here, but is there a way to create a new disk image with this?
...mathom...
