Vic 20 case latches
gw1sxp
Vic 20 case latches
Post by gw1sxp »
Hi,
Does anyone have any ideas as how to repair broken latches on a Vic 20 case.
Thanks
Re: Vic 20 case latches
gw1sxp wrote: Sun Jan 17, 2021 12:08 pm Does anyone have any ideas as how to repair broken latches on a Vic 20 case.
Do you still have the broken pieces? A couple of mine had broken off, I used epoxy glue to stick a 'C' shaped section of a hollow plastic lollipop stick over the pieces and that seems to have held well.
Alternatively you could try 3D printed tabs like these
https://www.soigeneris.com/commodore-64 ... s-bulk-pak
Yep you can find also in eBay 3D printed latches which fit well. I bought some in the past, not too expensive.
gw1sxp
Post by gw1sxp »
Hi srowe, orion70
Thanks for your help, very much appreciated.
No, I don't have any of the pieces from the latches.
Regards
gw1sxp
Post by gw1sxp »
Hi,
Can't find any 3d printed latches on ebay , does anyone have a link to an ebay seller.
Thanks.
Regards
Do you know anyone locally that has a 3D printer? The blueprints for the tabs should be available for download.
gw1sxp
Post by gw1sxp »
Hi Orion70, srowe
Thanks again for your brilliant help.
The ebay link is exactly what I am looking for.
Also, I don't know anyone local with a 3d printer.
I'm near to completely repairing my Vic20, thanks to all the great help on this forum.
Regards
