Hi,
Yes, i use an old OCR named "EasyReader Classic Edition"...
But, most of scanned picture are in poor definition (150dpi).
I had to change the main picture:
-Resize the picture X2 and fixe it to 300dpi.
-Apply a sharp module twice to avoid blur.
-Refocus grayscale to removing darker grey scale and get pure black ink on characters.
A raw text output is available.
The next step is a character replacement on OCR errors "l"="1", "O"="0" ...
"PRIt4T"="PRINT" (or "t4"="N"... Many errors are similar)
But, you had to jump all graphic characters... and add them in the 'PRG generator' !
It's a long work on a text editor, but I earn my time regard an emulator type-ins..."Where is the key?"
![Image](http://download.abandonware.org/magazines/Hebdogiciel/hebdogiciel_numero100/min/Hebdogiciel%20100%20-%20Page%20007.jpg)
Check OCR OUTPUT (not compared with original codes!)
http://www.hebdogiciel.free.fr/hd-roms/ ... nRace2.txt
I had to check all values line by line, but all (!!!most of!!!) values are available.
Good luck to me!
