Boray Gammon (Now V2.0)
Re: Boray Gammon
Note that you can add your score to the high-score page (and compete with others) even if you didn't win the match! For example, loosing with 5-7 against Clever Vic is still better than 3-7 or ...0-7!
Re: Boray Gammon
I lost today (4-7) but managed to win 12 matches in a row before that. Probably a hard record to beat.Boray wrote:I just broke my record and won with 7-0.
I've also won 11 seven point matches in a row now. I wonder how many I can manage.
http://sleepingelephant.com/denial/wiki ... h_Scores#B
- Mayhem
- High Bidder
Re: Boray Gammon
Just to note, there's a tiny box about the game in the homebrew section of the current issue of Retro Gamer...
Re: Boray Gammon
Nice! Any chance you can scan that for me?Mayhem wrote:Just to note, there's a tiny box about the game in the homebrew section of the current issue of Retro Gamer...
Re: Boray Gammon
Or a picture with a smart phone will do.
- Mayhem
- High Bidder
Re: Boray Gammon
Yeah, can do that, when I get back home (currently out this weekend).
Re: Boray Gammon
Re: Boray Gammon
Here is something me and my mother have tested out for about a month:
http://boray.se/commodore/gammon/bgammonwin.zip
It's Boray Gammon with a Windows environment: VICE emulator + help program for playing with an opponent over a network/shared folder. Double click start.exe to start.
The help program contains help for the emulator/vic novice on how to play against the computer, and how to play with an opponent over the internet. The program checks if the opponent has made a move and then pops up boray gamon and plays a sound for you to make your move.
The program is in Swedish for swedes and (hopefully) in English for the rest of you.
Re: Boray Gammon
Source for the help program if anyone is interested:
Public Class Form1
Shared last As String = ""
Shared ao As String = "VICE är väl redan öppet?"
Private Sub Timer1_Tick(sender As System.Object, e As System.EventArgs) Handles Timer1.Tick
If BackgroundWorker1.IsBusy Then Exit Sub
Try
Dim a As String = My.Computer.FileSystem.ReadAllText("vice\BGAMMONSAVED")
If (a <> last) And (a <> "") Then
go()
End If
Catch ex As Exception
End Try
End Sub
Sub go()
If Not BackgroundWorker1.IsBusy Then
Me.Focus()
Me.BringToFront()
Me.WindowState = FormWindowState.Minimized
Me.WindowState = FormWindowState.Normal
Me.Update()
BackgroundWorker1.RunWorkerAsync()
End If
End Sub
Private Sub Form1_Shown(sender As System.Object, e As System.EventArgs) Handles MyBase.Shown
Timer1.Enabled = True
go()
End Sub
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
MsgBox(ao)
Else
go()
End If
End Sub
Private Sub BackgroundWorker1_DoWork(sender As System.Object, e As System.ComponentModel.DoWorkEventArgs) Handles BackgroundWorker1.DoWork
My.Computer.Audio.Play("vice\bghelper.wav")
Shell("vice\xvic.exe vice\boraygammon.prg", AppWinStyle.NormalFocus, True)
Try
last = My.Computer.FileSystem.ReadAllText("vice\BGAMMONSAVED")
End Try
End Sub
Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
If Not My.Computer.Info.InstalledUICulture.DisplayName.ToLower.Contains("svenska") Then
Button1.Text = "Open the game"
Me.Text = "gammon help"
ao = "VICE is already open?"
RichTextBox1.Text = Form2.RichTextBox1.Text
End If
End Sub
End Class
- joshuadenmark
- Big Mover
Re: Boray Gammon
Great package - out of the box Boray Gammon - Can recommend this, as it's so easy to start.
Re: Boray Gammon
- Mayhem
- High Bidder
Re: Boray Gammon
Ah yeah, sorry, forgot about doing that when I got home. Least someone else was able to cover...
Re: Boray Gammon
No worries, I wouldn't have known about it without you. Thanks!
Re: Boray Gammon
New Release: V1.52
http://www.boray.se/commodore/gammon/
News:
* The AI routine for racing home ("run") was improved, resulting in 15% more points won in the long run against V1.45.
* When someone wins, it now shows which AI player you played against as well as the program version number. This so that you can take a picture and show off your high score. Pictures from previous versions doesn't tell much in this aspect.
I also run a test game against gnu backgammon, which now rates boray gammon as "Expert":
News:
Re: Boray Gammon
New release V1.68
News in V1.68:
* The running home algorithm was improved a bit more.
* Bugfix 1: The AI got stuck at a certain board condition. ( http://museum.boray.se/#!album-10-28 ) The bug must have been there since the speed improvements in V1.21.
* Bugfix 2: Running forever could have resulted in a stack overflow error (bug introduced in V1.52).
* A few visual changes.
News in V1.68:
