I operated MINIMON with one of my Mega-Carts for a comprehensive suite of tests. While doing so, I (re-)extracted the MC-specific version of TRON with a freeze reset:
Unlike the original version as contained in my Games collection, the MC-version of TRON (download) is internationalized and features English or German instructions at the title screen.
With the page-wise ASCII memory display (one of MINIMON's transient tools) I also found a hidden game that appears at $7000 when VICMON at $6000 is activated. This happened to be yet another variant of City Crusher.
For completeness, here's a closeup of the controls:
WIP: VIC-2020 MINIMON cartridge
Re: WIP: VIC-2020 MINIMON cartridge
You could ask me
Yes, City Bomber, it is on the EXTRA section (F2 from the initial screen to access to this section)With the page-wise ASCII memory display (one of MINIMON's transient tools) I also found a hidden game that appears at $7000 when VICMON at $6000 is activated. This happened to be yet another variant of City Crusher.
I'm happy you still enjoy your Mega-Cart along with your MINIMON cartridge
For unknown reasons I did not keep a copy of the adjusted version. Anyway, extracting the game made an interesting test case for MINIMON.nbla000 wrote:You could ask me.
Indeed, there it is. I only searched in the cartridge and tape/disk games but missed out this one.Yes, City Bomber, it is on the EXTRA section (F2 from the initial screen to access to this section)
Yes, I operate my VIC-20 with MC and a C64SD most of the time.I'm happy you still enjoy your Mega-Cart along with your MINIMON cartridge.
A cartridge like Mega-Cart, with extra logic for RAM or ROM banking is a much more demanding test case than a standard RAM expansion. The I/O de-multiplex logic of the MINIMON cartridge ensures a minimal delay (only about 5 ns) on the I/O2 and I/O3 select signals when the switch is set to the "CART" position.
I expected MC to init its internal banking registers for "no RAM expansion" and "Mega-Cart firmware in BLK5" when it receives a hardware reset signal, either from its own reset circuit or from the VIC-20 reset circuit. In case of a MINIMON freeze reset, the reset line is opened and pulled high in direction to the cartridge in the extender - thus that cartridge, MC in particular, should keep its own selected RAM/ROM configuration prior to the freeze reset. That is exactly what happens: if I select "no RAM expansion" from the MC menu, a freeze reset keeps that (and puts me at the normal start-up banner of BASIC), if I select "+32K RAM" before, a freeze reset will keep the +32K RAM config as well, and if a cartridge game has been selected before, it is still mapped in after freeze reset. Then I set the switch to "MON" and inspect the cartridge memory.
If you're going to start selling soon, a regular socket will probably be sufficient. How often are people really going to swap out MINIMON? Not very. Geez, I can hardly get 2732s that actually work. I've pretty much given up on 24-pin anything. MINIMON is likely to just stay there forever when I get my copy.
To all concerned:
MINIMON has been released on sourceforge, under the CC-BY-SA 4.0 licence.
Here is the draft of the first hardware design, should anyone want to replicate the prototype cartridge shown in the introductory post of the thread using a VIC-1210 +3K RAM expansion as carrier:
You find the firmware here.
1 -|A7 Vcc|- 24
2 -|A6 A8|- 23
3 -|A5 A9|- 22
4 -|A4 Vpp|- 21
5 -|A3 /OE|- 20
6 -|A2 A10|- 19
7 -|A1 /CS|- 18
8 -|A0 D7|- 17
9 -|D0 D6|- 16
10 -|D1 D5|- 15
11 -|D2 D4|- 14
12 -|GND D3|- 13
- open pad 12 lower
- close pad 12 upper, connect Pin 21 (Vpp) to +5V
- open pad 5 (-> pin 20 upper chip, /OE)
- open pad 11 upper (-> pins 18 upper and lower chip, /CS)
/CS := /I/O2 & /I/O3 == //(/I/O2 & /I/O3) -> to pad 11, right
/OE := /(CR/W & SO2) -> to pad 5, right
