Gamebase20 version 3!
- Mayhem
- High Bidder
- Vic 20 Devotee
Gamebase Game : Breakout Publisher: (Unknown) is Breakout (1982-12)(IPC)[Your Computer][type-in]
http://archive.org/stream/your-computer ... 5/mode/2up
Gamebase Game : Frogrun Publisher: (Unknown) is Frogrun (1983-05)(IPC)[Your Computer][type-in]
http://archive.org/stream/your-computer ... 1/mode/2up
Gamebase Game : Rescue Publisher: (Unknown) is Rescue (1984-04)(Micro Systems Specialties)(US)[Commander][type-in]
http://archive.org/stream/commander-mag ... 9/mode/2up
Hi Mayhem,
Nice work - I tested on Windows 8 on a Samsung ATIV, Intel Atom processor.
Seems to work fine.
Some missing screenshots but I saw your note on this.
I found some missing games : Stack Light Rifle collection had 3 games. I know they won't work in the emulator for now but should maybe be added to the archive. They were available here. If you don't have them let me know and I will look out my backup copy.
http://sleepingelephant.com/ipw-web/bul ... e&start=15
Seems to work fine.
- Mayhem
- High Bidder
- Mayhem
- High Bidder
- Vic 20 Devotee
- Mayhem
- High Bidder
If in doubt, run it against Vice 1.22 first in these situations. I just tried it and it does load on 1.22.
Vice 2.x tightened up the TAP quality levels in regards to errors and distortion, and a bunch of TAPs that loaded fine in 1.22 suddenly don't work in 2.x. This happens to be another one, so if someone can oblige and redump the tape, then I'll swap it out.
- Vic 20 Devotee
- Mayhem
- High Bidder
Really? Hmmm... either way, a redump is still the first way forwards. The game is definitely unexpanded, I have the Galactic Software version somewhere I believe.
(which is essentially the same because it's the company the Darling brothers ran before licensing stuff to Mastertronic, and then went onto form Codemasters)
- Vic 20 Devotee
meaning the game works well in VICE v2.1 using unexpandedMayhem wrote:Really? Hmmm... either way, a redump is still the first way forwards. The game is definitely unexpanded...
another question :
The Game Alien Panic by Nüfekop
Are you sure it's from 1981 ? ' cause titlesreen says 1984
Edit :
another one : Tape file of Alpha Blaster (1983)(Sumlock) works only in VICE v1.22
- Mayhem
- High Bidder
I have 3D Maze myself, having checked my collection, so I can try to redump that here. Someone else will have to redump Alpha Blaster as I don't own it (Bo?).
Alien Panic was 1981 according to Scott Elder. I can only presume it was a v2 of the game or similar he sent me.
