VIC-20 Disk Menu on a Cartridge
I think so too... Thanks!
/Anders
/Anders
Seems I now have got it working! It works better in 1541-speed than 1540-speed for some reason. So I switch it down to 1541 speed for the directory read and then back again. I also use CHRIN instead of ACPTR. Anyway, it now reads the directory with a speed of 6 filenames per second. I think that is pretty fast. The old program only managed 1.6 filenames/second. I have also added the printing function. I will probably upload the new version tomorrow. Thanks again Björg for the great tip!!! I think I will have a lot of help of that trick in the future.
I am now listening to Sweden-Switzerland in the hockey quarter final on the radio (2-1 right now). I don't hav TV3 so I can't see it on TV But I'm happy anyway now when I have got the menu working I have worked quite hard with that ML directory for two whole days...
/Anders
/Anders
Great news about the software development. As long you only need a numeric value, it may be interesting to have a look at the USR() function too. It is a little different to use, but pretty cool if you find an usage of it. WAIT is also an interesting instruction which should be possible to use in combination with your own routines, at least if you have installed something that runs on interrupt.
The icehockey.. I stopped bothering ten years ago, but the final result was as you posted it. I do have the broadcasting TV channel, but it gotta be a really important game or I would be bored to watch it these days.
I was a bit haisty in saying that it worked... Because it didn't.... It still stops sometimes... I won't upload it today anyway...
But it seems to work a lot better now since I start every ML routine with a call to SETTMO to turn off some time out. (It works pretty well in 1540 speed too). But I will try to improve it more...
/Anders
/Anders
I have fixed it now! (I hope! ) I thought the locking of the computer happened somewhere in my ML routines so I made many changes to them, and that took some effort as I'm using Hesmon on a real vic-20. But it turned out that my ML routines were fine all along. The problem was that I mixed them with the basics GET# command. It was when returning from the ML and using GET# when the computer hang... sometimes. Not often... like one time out of 900 maybe... Problems like that are hard to find...
Anyway. It now works fine and reads the directory with the quite amazing speed of 9.6 to 9.99 filenames per second. So I am wondering - with this speed, would you still like to keep the functions to save and load a list, sort and remove items from it? Removing those functions would of course save some space. I am also wondering if you ever use the "8" and "1" keys, or if you always use "return" for auto load?
/Anders
/Anders
It's now up in 10.7 names/second...
I removed the list things and now have:
F1: Help
F5: Refresh
Crsr up&down
Space
Return
8
1
D delete
P print
and R for rename.
It's now 6 blocks (the basic). I don't know if I will keep "8" and "1". I have never used them...
What do you think?
/Anders
F1: Help
F5: Refresh
Crsr up&down
Space
Return
8
1
D delete
P print
and R for rename.
What do you think?
/Anders
I kept the "8" and "1"... They didn't take up that much anyway... It's just 6 blocks now with ML and all included. I think it's ready now.... For the fun of it, I made some speed comparances of how long it takes to load a 128 files directory:
Our menu: 13 seconds
Load"$",8 on 1541: 12 seconds
Load"$",8 on 1540: 10 seconds
Directory command on FinalCart/C64: 16 seconds
Directory command on C128 with 1571: 13 seconds
Directory command on 2MHz C128 VDC 1571: 10 seconds.
Load "$" on above 1571: 4 seconds
(Searching for $ included)
/Anders
/Anders
And as it's smaller now, running on the unexpanded vic the menu can now handle something like 126-128 names!
I don't know what sfd1001 is... But the 1581... It can handle more files right? Then you need to change line number 5
5 P=145:IFPEEK(... etc..
Exchange the P=145 above to the maximum number of files that the 1581 can handle.... And that will only work on the expanded vic. On the unexpanded, 128 is still the limit because of the small memory...
There is also a limit of the name lenght of 16 characters. If the 1581 can have longer names, then you have to make M$ longer on line 9.
/Anders
/Anders
