I don't get it.16KVIC20 wrote:I would like to type some in at the very least and save them to tape.
I mean, all the hard work's already been done by tokra - namely typing in the programs. He made them available in the most compact way, as a 1:1 memory dump, i.e. a *.prg file.
You seriously want to: load them into VICE, export them as text data (in a way orion70 described), and then *type* them in once again on the real VIC-20 just to be able to save them to tape?
Besides, you'll be show stopped on the two listings as soon as you get to the quoted numbers in angle braces (like {221}). These correspond to characters typed in with the C= key, though the detokenizer used here is not very helpful to indicate, which key should be pressed together with C=.
