In the making: Arukanoido – an Arkanoid clone
Re: In the making: Arukanoido – an Arkanoid clone
Tried the version 942 you posted. They sound absolutely the same whether I use joystick or paddles. What sounds are you referring to? Laser/block/starting music/game over all are either samples or VIC depending on whether I press M at the start or not. The ball and block-sound is always VIC no matter what. I tried the .tap and the .prg-versions.
Edit: Ok with rev944 you sent I now get only beamrider's VIC-sounds when using paddle-mode. Not that I noticed slowdowns with the samples before. Some samples (like the GameOver-music) sound rather "scratchy", and as such I usually prefer the cleaner VIC-sounds.
- pixel
- Website: http://hugbox.org/
Yep. I noticed but put it to low priority. Samples must be wrapping somewhere. Generated data looks OK. Monitor audio files also sound OK. Perhaps something with the NMI code.tokra wrote: ↑Mon Nov 23, 2020 11:50 am Edit: Ok with rev944 you sent I now get only beamrider's VIC-sounds when using paddle-mode. Not that I noticed slowdowns with the samples before. Some samples (like the GameOver-music) sound rather "scratchy", and as such I usually prefer the cleaner VIC-sounds.
Outro is missing as well as the hiscore table. Did I promise animations? head -> wall. :p Perhaps I'll skip the latter and get this thing out for good with the last bugs fixed. Even Hitchcock couldn't take that much suspense.
And a splash screen and logo would be nice, too. Then the things to be printed. This is all making me have breakfast and reject whackcine (German lager).
- pixel
Revision 946 is up.
I personally prefer the Vic sound as it sounds more like... a Vic but obviously I am biased.
It would be nice to see all the arcade animations and etc in though. We've waited this long, you might as well finished it off properly (IMO). I regret not making a 32K Pooyan with the missing cut scenes etc. That's why I went the whole hog with Popeye and included pretty much everything from the arcade that I could.
btw, OT: If you could hack Gorf and add the arcade speech using your new digii routines, that would be awesome...
I'm all for the "deluxe"-version as well. But: In the end it's your baby and you decide what to do with it. You could do a "George Lucas" on it and release a normal version soon and a special edition in 20 years beamrider: You could do the same with Pooyan, release a special edition with the extra features for +32k
- pixel
The animations: that'll be a lot of clicking around in your VIC screen designer. That's how the mother ship got converted. So that's about 20 more times. There might be some feature request coming up again. Too sad the bitmap2charset generator didn't make it in.It would be nice to see all the arcade animations and etc in though. We've waited this long, you might as well finished it off properly (IMO). I regret not making a 32K Pooyan with the missing cut scenes etc. That's why I went the whole hog with Popeye and included pretty much everything from the arcade that I could.
As for Gorf: I'd be curious how VOTRAX programming works in the first place. Disassembling and reassembling shouldn't be too much of a deal with the cc65 suite. Perhaps an own thread for that would be in order to collect ideas.
bitmap2charset ?
I think there's a feature that looks for and consolidates similar characters..
[edit]
http://www.fox-ts.co.uk/betavic20sdd/Vic20SDD.htm
Tools/Consolidate Duplicate Characters.
Is that what you meant?
[edit]
- pixel
My baby!? T'wasn't even my idea... blame the ladies!tokra wrote: ↑Tue Nov 24, 2020 8:08 am I'm all for the "deluxe"-version as well. But: In the end it's your baby and you decide what to do with it. You could do a "George Lucas" on it and release a normal version soon and a special edition in 20 years beamrider: You could do the same with Pooyan, release a special edition with the extra features for +32k
Speaking of special edition: meanwhile I realized how to crunch even more into the unexpanded core of PULSE... and I'm terribly unhappy with the intro before the splash screen. The tape audio player also got improved. boray's tune could get a better conversion. The first enemies should occur a second later, etc. And the audio boost is also missing... can make tapes again, but the pandemic has to go first.
- pixel
Oh, yesyesyes. Never mind. Thanks!
IMHO, there's limited value in updating existing already released games.
I made a new version of Pooyan 2015 with some improvements and better sprites, but people still play/review the original version, I think the early reviewers take copies and host it on their own server then others find it from there and don't notice updates. Perhaps if it's radically better it will make waves, but otherwise exposure is limited.
Much better to concentrate your energies on new things - again IMHO.
- pixel
Just a few patches. Most already done. I'll go back to University and finally study IT.
Hi, i'm trying to make version .946 to work but cannot load the game, just stuck into a screen full of undefined blocks of pixels.
I'm on a VIC with Penultimate+ (35 k expansion) and Tapuino.
Is there something i am missing?
- pixel
Works fine on a real machine with a simple 24K expansion from SD2IEC or tape AFAIK. On VICE, too. No clue really. You're the first to complain.
- pixel
I might have found a solution by accident: not enough memory expansion enabled?
