Bitmap graphics demos/slideshows (by Miklós)
- Occupation: butcher
Re: Bitmap graphics demos/slideshows (by Miklós)
Hi all.
LEO zodiac 8k
3 color+black multicolor mod picture,multicolor 1pixel ultra fine left scroller.
-color setup, Custom color combination option.
I am a lion zodiac sign.
LEO zodiac 8k
- LEO ZODIAC 8K.zip
- (4.2 KiB) Downloaded 101 times
- leo.PNG (8.58 KiB) Viewed 2929 times
Hi all.
deep magic of the see 8k
21x24 char screen on 37x24 char picture
bitmap 1pixel left scroller.
- deep magic of the see.zip
- (4.91 KiB) Downloaded 128 times
Hi all
Hi-res picture 1 pixel right scroll. 8k
- HIRES R SCROLL8K.ZIP
- (6.14 KiB) Downloaded 119 times
Hi all
- MKS DEMO3 dec16.zip
- (22.53 KiB) Downloaded 106 times
- ST.PNG (6.03 KiB) Viewed 2791 times
Hi all
Duran Duran 16k
2 picture on left scroller.
Duran Duran 16k
- MKS DEMO3 dec17.zip
- (29.55 KiB) Downloaded 107 times
Hi all
Two trees 8k
-Interlace picture.
Two trees 8k
-Interlace picture.
- MKS DEMO3 jan03.zip
- (42.29 KiB) Downloaded 93 times
- two trees.PNG (18.67 KiB) Viewed 2726 times
Miklós,
I have already mentioned this in passing in one of my earlier postings here in the thread, to repeat: your picture converts would improve a lot if you'd take the pixel aspect ratio into account.
On a PAL VIC-20, hires pixels are not square. They are 1.67 times longer in width than they're tall. Correspondingly, multi-colour pixels are 3.33x wide as tall. In fractions with small integers, 5/3 and 10/3. For NTSC, the numbers are slightly different: 1.50 to 1 for hires and 3.00 to 1 for multi-colour.
On a PAL C64, hires pixels are nearly square, 0.9 (width) to 1 (height) is more accurate (1.8 to 1 for multi-colour). On an NTSC C64, hires pixels are vertically elongated. Here, the numbers are 0.75 (width) to 1 (height) for hires and 1.50 (width) to 1 (height) for multi-colour.
As long as you - sorry - toy around with 1:1 pixel converts from C64 -> VIC-20, this inevitably leads to flattened results, which just look bad.
That also means, 'source' material from another computer is a rather inconvenient start point. Rescaling to correct for the different pixel aspect either loses detail in one direction (when pixel columns/rows are left out) or gives a coarse result in the other direction (when pixel rows/columns are duplicated). Much better is starting out from a much higher resolution original on the PC.
This is what I've been doing with my MG batch suite for all the years now. I use PGM IMPORT and PGM IMPORT MONO to import greyscale and lineart pictures. In Irfanview, I first select a suitable part of the picture with an image aspect ratio of ~1.389 to 1. (1.389 ~= (160/192) x (5/3) - the first factor comes from the pixel resolution of MINIGRAFIK, the second factor is aforementioned pixel aspect ratio). The cropped intermediate result then has the same width/height over the whole picture as it later appears on the VIC. I then resample this cropped part of the source image - and this is important! - with "Preserve aspect ratio (...)" ticked off, to either 80x192 pixels (for PGM IMPORT) or 160x192 pixels (for PGM IMPORT MONO) and save them as *.pgm files. These then go straight into the MG tools and result in a picture file in MG format.
Here's one of the example converts I did this way (the picture is contained in the *.d64 of the MG batch suite). You also took that one as example for your slideshows:
And here is the original, uncropped photo I started with:
You see it can be done right. There's no good reason to have 'fat' faces or other flattened scenes on the VIC-20.
Hi all
New stuff:
2 animation and 7 picture.
New stuff:
- Rayt v4+new pic preview 1-1.zip
- (284.25 KiB) Downloaded 121 times
HI
VIC MAX picture 8K
VIC MAX picture 8K
- MAX.ZIP
- (4.36 KiB) Downloaded 106 times
- MAX.PNG (5.73 KiB) Viewed 2519 times
Love the Max Headroom!
Hi
A bunch of new stuff.
- DEMO MKS.ZIP
- (418.53 KiB) Downloaded 84 times
Hi All . Halloween part.
Cauldron picture from spectrum unexpanded
2022 01.11. JETPAC+ PIC 24K PAL/NTSC
-Byt loader demo.
28*23 / 8x8 charset Screen .
1 byt copy to bitmapp.
--new 28 charset picture --"bitmap copy demo"
- old 32char / row char pictute
--viewed VICE emulator 3.2 / settings -- Border debug --
--look 32 char/row charset total picture on PAL vidostandard.
- first 26 char / row picture on demo.
SKULL ANIM 1.1 8k
-Byt loader demo.
SKULL ANIM 1.1 8k
- SKULL ANIM 1-1.PRG.zip
- (2.64 KiB) Downloaded 100 times
- MKS DEMO4 01 11 22.d64.zip
- (104.96 KiB) Downloaded 80 times
- MrSterlingBS
After searching some converting tools for a title screen of my game i found this website.
https://8bitworkshop.com/dithertron/#sy ... angogh.jpg
Maybe someone can use the tool.
Sven
Sven
Dithertron is great! There's also this one: https://mcdraw.xyz/
I'm struggling to get one of those cool advanced gfx formats to work that use stable rasters to change colors on the fly.
