V-FORTH - Forth-83 for the VIC
- Vic 20 Hobbyist
Re: V-FORTH - Forth-83 for the VIC
Where can I find version 4.9.
I only have 4.7.
Thanks for your patience and help.
Greetings Armando
I only have 4.7.
Greetings Armando
- Vic 20 Hobbyist
I finished and saved the snake program with Autosave
taken from the Forth c64 version.
I can't find a program to write Seq files.
With what program did you write the Demo.fs files. ??
I only have programs for Vic20 and c64 that read and print Seq files but don't write them.
Attached is the Snake. file
Load "snake.prg",8,1 : Sys8192
Thanks for help. Armando
Very colourful.
I don't edit files actually on the VIC, I prefer use an editor on my desktop PC and copy them into a disk image. I use my own tools (cbmshell) but you can also do this with the c1541 program which comes with VICE.I can't find a program to write Seq files.
There are probably text editors on the VIC you could use, I don't know of any myself.
- Vic 20 Hobbyist
HI,
I insert two listings that I made.
One normal and the other for Minigrafik.
I would like to have them in Vforth if possible.
They both work but the execution speed is very slow, especially for the version with minigrafik.
I am sure that with the Vforth they will be faster.
Thank you . Greetings Armando
This is an unfair and misleading comparison! The version in pure BASIC only works on the text screen, whereas the MG version sets pixels in the graphics screen and correspondingly has to operate on 64 hires pixels instead of 1 single character cell for a given screen estate.armypavarmy wrote:They both work but the execution speed is very slow, especially for the version with minigrafik.
Here is how I would implement those Automatons with MINIGRAFIK. The first line are random pixels, subsequent lines have Rule 110 applied (can be changed with the values in line 9):
1 X=RND(-TI):CLR
2 FORL=0TO1:FORM=0TO1:FORR=0TO1:READC(1-L,1-M,1-R):NEXT:NEXT:NEXT
3 @ON:@CLR:FORX=0TO159:@RND({PI})+.5,X,.:NEXT
4 FORY=0TO190:@C(@(159,Y),@(0,Y),@(1,Y)),0,Y+1
5 FORX=1TO158:@C(@(X-1,Y),@(X,Y),@(X+1,Y)),X,Y+1:NEXT
6 @C(@(158,Y),@(159,Y),@(0,Y)),159,Y+1:NEXT
7 GETA$:IFA$=""THEN7
8 @RETURN:END
9 DATA0,1,1,0,1,1,1,0
Forth could do all relevant calculations with byte and word values. That surely is faster than the (implied) float arithmetic of BASIC. Nothing to prove here.
My graphics vocabularies don't currently have a word to test if a pixel is set, I'll add one and then post a FORTH implementation.
I've been recently trying to implement an efficient Game of Life, but even with optimizations it's very slow.
- Vic 20 Hobbyist
Thank you.
if you can, the low resolution version (Basic) converted to Vforth is also fine.
I would like.
Greetings Armando
I would like.
Greetings Armando
Here's the equivalent of the BASIC (text mode) version in FORTH
variable n
: wolfram-text
150 n !
147 emit
37888 dup 512 0 fill
0 4106 c!
begin
4586 4097 do
i 1- c@ 2*
i c@ + 2*
i 1+ c@ +
5 rshift
1 swap lshift
n @ and if
32
else
0
then
i 22 + c!
loop
1 n +!
again ;
- Vic 20 Hobbyist
HI,
thanks for help. I try to do it.
Greetings Armando
Greetings Armando
- Vic 20 Hobbyist
HI,
Here is the Automata .Prg file.
Version with Vforth.
Very beautiful and fast.
Load with Load "automata* ",8,1 : then Sys 8192.
Thanks to the author (Srowe) for the cooperation.
I'd nearly forgotten about this. I've added a new example to the latest release which contains 3 versions: text, low resolution and high resolution graphics.
