V-FORTH - Forth-83 for the VIC
Re: V-FORTH - Forth-83 for the VIC
It's probably UNIX line endings, I convert the files automatically when building the disk image. Try this file.
- demo-case.zip
- (422 Bytes) Downloaded 136 times
thank you for your effort.
it's not working.
exactly the mistake as with the lineto.
one please, do case and lineto times on a vforth.d64?
Thank you.
greeting
it's not working.
Thank you.
greeting
I'm on vacation now and don't have access to my computer. You should be able to paste each line into a new file.
Hi good afternoon.
all the best on vacation.
I re-typed all the lines in my case.
the same mistake comes here too.
Thank you.
greeting
Thank you.
greeting
Here is a new build with a case module complete with example file.
- vforth.zip
- (54.81 KiB) Downloaded 105 times
Not worked on this for a while but here's the latest build which includes support of loading MINIGRAFIK images.
- vforth.zip
- (55.12 KiB) Downloaded 106 times
- pixel
- Website: http://hugbox.org/
Too sad that the Git repo has gone. Moved some place else?
Shouldn't have, but I re-installed the server so I could have broke something. Let me check.
Are you browsing it from https://eden.mose.org.uk/gitweb/?p=vforth.git;a=summary or cloning it?
Edit: if you were cloning it with a remote containing /var/www/html/vforth.git I've added a symlink which should have fixed it
- pixel
It resurfaced. Thanks! Am cloning it.
EDIT: Now some "d64-format" is missing. can it be replaced with VICE's c1541 image tool?
- Vic 20 Hobbyist
Hello everyone
This listing I took from the C64 version
It doesn't work with the Vicforth because the RND command is not recognized.
How to add it to Vfort V4.7??
Thanks for help.
Thanks for help.
- oneline Vic20- Forth.jpg (54.26 KiB) Viewed 1452 times
There's no RND word defined in any FORTH standard as far I know. I've used a linear-feedback shift register (LFSR) as a random number generator in some of my examples.
Assuming that your code expects limit RND to return a random integer between 0 and limit-1 the following should work
variable rndseed
44257 rndseed !
: rnd
rndseed @ dup 7 rshift xor dup 9 lshift xor
dup 13 rshift xor dup rndseed ! 1- swap mod ;
- Vic 20 Hobbyist
Thanks for help.
I need instructions to use the Autosave.fs
to save the written file.
Greetings
Greetings
I've just tried to walk through an example of using AUTOSAVE and it isn't working. I'll need some time to look into why.
- Vic 20 Hobbyist
Thanks for the help. I await news
Greetings. Armando
Greetings. Armando
I've released 4.9 which has a fixed AUTOSAVE.FS
You can use it as follows:
Given a program like this
include the autosave module and save the dictionary
Reset then load and run your program with
: EXAMPLE
CR ." HELLO" CR ;
INCLUDE AUTOSAVE.FS
' EXAMPLE AUTOSAVE MY-EXAMPLE
DLOAD MY-EXAMPLE
