V-FORTH - Forth-83 for the VIC
Re: V-FORTH - Forth-83 for the VIC
It's very easy to lose track of the stack contents. I'd recommend adding a comment to each word to document what is expected before a word executes and what should be left after.
the mistake is in yours.
even if it is empty comes the stack overflow
: test
begin until ;
greeting
: test
begin until ;
greeting
hello, thanks for the info.
greeting
greeting
hello good day.
this not funktion in vforth 4.0
INCLUDE DEMO.FS
INCLUDE AUTOSAVE.FS
' MAZE AUTOSAVE MAZE.PRG
tanks
greeting
INCLUDE DEMO.FS
INCLUDE AUTOSAVE.FS
tanks
greeting
Hi good afternoon.
Can you please put the start of vforth on 9216 so I can make graphics at 4096 (506 ascii)?
Thank you
greeting
Thank you
greeting
Hi good afternoon.
Can you please put the start of vforth.prg and vforth.com on adress 9216 so I can make graphics at 4096 (506 ascii)?
Thank you
greeting
Thank you
greeting
I'm not sure why moving to 9216 ($2400) helps you. You can't use $2000-$23FFF for graphics as the memory isn't addressable by the VIC chip. Moving the ROM image isn't possible, it occupies the whole the the 8kB space.
I need the memory of 5120 - (5120 + 4080)
for 510 chars. the screen goes from 4096 - (4096 + 506).
The screen has 506 chars.
thank you for your help.
greeting
greeting
this not funktion with autosave.
starting programm with "gehe"
greeting.
greeting.
variable xb
variable yb
variable fb
variable pw
variable sw
variable cw
variable oxb
variable oyb
variable testj1
variable testj2
variable testj3
variable z
variable test
create daten
24 c, 24 c, 60 c, 126 c, 255 c, 24 c, 36 c, 66 c,
255 c, 129 c, 129 c, 129 c, 129 c, 129 c, 129 c, 255 c,
hex
: joy
1 9122 c@ dup 7f and 9122 c!
9120 c@
swap 9122 c!
80 and if 1- then
9111 c@ >r r@ 10 and 0= if drop -1 then
0 r@ 4 and 0= if 1- else r@ 8 and 0= if 1+ then then
1 r> 20 and if 1- then ;
decimal
: cls
511 0 do 32 i 4096 + c! loop
0 0 $plot ;
: setze
oyb @ 22 * oxb @ + pw ! 32 sw @ pw @ + c!
oyb @ 1 + 22 * oxb @ + pw ! 32 sw @ pw @ + c!
testj1 c@ 255 = if xb @ 1 - xb ! then xb @ 0 < if 0 xb ! then
testj1 c@ 1 = if xb @ 1 + xb ! then xb @ 21 > if 21 xb ! then
testj2 c@ 255 = if yb @ 1 - yb ! then yb @ 0 < if 0 yb ! then
testj2 c@ 1 = if yb @ 1 + yb ! then yb @ 21 > if 21 yb ! then
xb @ oxb c! yb @ oyb c!
yb @ 22 * xb @ + pw !
1 sw @ pw @ + c!
fb @ cw @ pw @ + c!
yb @ 1 + 22 * xb @ + pw !
0 sw @ pw @ + c!
fb c@ cw @ pw @ + c! ;
: time 1000 0 do loop ;
: wechsle 8 0 do 0 5128 i + c! loop ;
: wechsle1 16 0 do daten i + c@ 5120 i + c! loop ;
: joysetze
joy testj3 c! testj2 c! testj1 c!
testj1 c@ 255 = if setze then
testj1 c@ 1 = if setze then
testj2 c@ 255 = if setze then
testj2 c@ 1 = if setze then
testj3 c@ 1 = if wechsle then ;
: gehe
205 36869 c!
4096 sw !
37888 cw !
10 yb ! 10 xb ! 5 fb !
xb @ oxb ! yb @ oyb !
cls
setze
begin
time
joysetze
197 c@ 18 = if wechsle1 then
197 c@ 17 = if wechsle then
197 c@ 10 = if 1 sw @ c! 3 cw @ c! then
?terminal
until ;
Thanks, my question has settled.
I can indeed extend the char from 8 bytes to 16 bytes if
I poke 36867,151 enter.
thanks.
greeting
thanks.
greeting
Hi good afternoon.
it works now.
I had made it from the vforth.rom.
it only works with the vforth.prg from the disk
sys8192 and control with the joy.
Thanks
Greetings
it works now.
Thanks
Greetings
- gehe.zip
- (6.56 KiB) Downloaded 79 times
Hi good afternoon.
can you convert the autosave so that autosave can also be done by vforth.rom.
it is too cumbersome for me to start the vforth from the disk to autosave and then
start vforth.rom again.
Thanks & Greetings
Thanks & Greetings
