<dev.-#> is the device number. 1 (= tape) is default and you'd use 8 or 9 for floppy (higher device numbers like 10 or 11 must be given in hex).majikeyric wrote:Does it mean you can also load a file at any memory location ? overriding the file load address ?L ["<file name>" [<dev.-#>]] - load file into memory
The L command always loads a file to the same memory location it was saved from. This doesn't pose any problems in practice: 65xx machine code generally isn't relocatable anyway, and if you need a data block at some different place, the T command can be used for this.
O.K. for the two units.Count me in for 2 physical units and a software image for the Ultimem
If you own the hardware, you can always create a software image for yourself with the S command, but I won't do a software-only release.
