WTB: VIC-20 Cartridge Expander
- Vic 20 Devotee
- Vic 20 Devotee
Check to make sure there is not a short between any of the address bus or data bus pins of expander.English Invader wrote:Just tested the expander and all I get is a blank screen like you get with a faulty 6561 chip. When I turned the VIC on without the expander, I got the standard VIC screen as usual.
Does this indicate a faulty expander or is it more likely down to something I'm not doing properly?
![Image](http://www.6502dude.com/cbm/vic20/megacart/images/megacart_small.jpg)
- Pedro Lambrini
I was just browsing through eBay.com and came across this expander:
http://tinyurl.com/y858n8k
It's a little expensive but it seems to be new so maybe it's worth a try...![Smile :)](./images/smilies/icon_smile.gif)
- Vic 20 Devotee
Hi Pedro,
Thank you for the link.
I saw that on eBay the other day and looked up information on the CardBoard 3. Unfortunately, it simply allows you to plug in multiple cartridges and tries using all the cartridges that are plugged in at the same time. I actually need to switch from one cartridge to another. From the sounds of it, I may just be out of luck.
Maybe I'll just have to have two VIC-20s setup. One for each cartridge.
Unfortunately, I'm still waiting for my Final Expansion 3 to show up. ![Sad :(](./images/smilies/icon_sad.gif)
Heather
Heather
Hey... that's the one I have! It came bare when I picked it up in another person's collection, and so, I didn't have any information on it. Now I have more info... Thanks, Pedro!Pedro Lambrini wrote:I was just browsing through eBay.com and came across this expander:
Truly,
Robert Bernardo
Fresno Commodore User Group
http://videocam.net.au/fcug
The Other Group of Amigoids
http://www.sccaners.org
- Diddl
- Website: https://oe7twj.at/
- Occupation: software engineer
