VIC 20 in Black and White mode
- Pedro Lambrini
I'll employ an interrupt routine for this, which can run alongside any other program (even in BASIC) as long as it doesn't interfere with the interrupt.Pedro Lambrini wrote:Sounds interesting. A whole new range of colours...can they be used for game purposes or only in a demo situation?
Software only.saehn wrote:Wha-wha-what!? This sounds interesting. Is it implemented solely through software, or does it involve physically turning down the color on the monitor?
Here we go. (download)
A +8K RAM expander is required. In the *.d64, just load and run the file BOOT, and there you go.
The demo loads a picture, waits for a key press, then starts the raster engine, and the remainder of the BASIC program sets up the tables for greyscale output. Finally, a second key press returns to the READY prompt.
Greyscale output is achieved by mixing green, and purple for a dark grey, light green and light purple for a light grey.
The raster engine splits the auxiliary colour register off-screen, and the background/border register during flyback (to provide for the next border colour), *and* at the left, and right edge of the display window! This now allows for a separate definition of the "border" colour within the image from the border colour itself (I could have made left, and right border different as well, but there's no real use in that). Two different tables are used on alternate frames.
Both PAL, and NTSC versions of the raster engine are provided. I'd very much appreciate feedback whether the result on a real NTSC VIC-20 is in order - I could only test within VICE.
For the adventurous ones, try SYS15104 after the program has returned to the READY prompt.
Edit (2019-10-18): uploaded a slightly improved version and reflected the changes in the post here.
It looks nice, but it helps if the user turns down colour saturation a bit on the monitor. I like the screen you get after SYS 16384 too. The dark cyan is a nice touch.
Interestingly it seems to flicker less on NTSC than PAL, or maybe it is due to I can only get B&W image from my NTSC VIC-20. It could also be a matter of each VIC has its own kind of video output, which we kind of already knew.
Some people are more sensitive to colour flicker than others. It's the same matter with video beamers, where a red, green, and blue image are projected.carlsson wrote:It looks nice, but it helps if the user turns down colour saturation a bit on the monitor.
That should be the same light grey as in the image ... ? Maybe the yellow border contrasts to the grey, and fools one into seeing cyan as complementary colour.I like the screen you get after SYS 16384 too. The dark cyan is a nice touch.
I more meant to try it because of the timing issues. Both normal text screen, and MINIGRAFIK screen are supposed to be centered, but the raster engine takes its timings from the bitmap screen. Therefore the "outer" border colour definition should extend one whole character into the text screen on both sides (20 vs. 22 columns). Likewise, the effect should start 4 raster lines earlier, and end 4 lines later than the text screen (24 vs. 23 rows). And, of course, BASIC still can be used, the program listed, etc.
Well, NTSC has an already higher frame rate to begin with. 60 Hz vs. 50 Hz give a noticable difference.Interestingly it seems to flicker less on NTSC than PAL, [...]
This kind of programs is highly sensitive to emulator issues:
In VICE 1.16 (that's the version I still mostly use), the effect stops working (even though it doesn't crash the VIC) after - in PAL - ~65 minutes. In that time, 2^32 machine cycles pass. Then, the emulated VIC and VIA chip suddenly get out of sync! While I didn't really expect something like that to happen, I had added a check within the IRQ server, whether the delay between IRQ and the entry into the IRQ routine was outside a sensible range - and then the effect is disabled.
The newest VICE beta has yet another problem. Here, the splits don't anymore happen on character boundaries, or in the half of each character, but somewhere else.
Hm, am I seeing colours that are not supposed to exist?
Sorry for the poor sharpness. I really need to get myself a better PAL VIC-20 since internal adjustment or replacing the 6561 did no difference. Actually I have at least one more loose VIC with better image but it doesn't load from disk (Ruud suggested replacing the 7406 next to the 6522 but I haven't got to that yet).
Thank you for the picture!
Indeed, I had only VICE available at the moment ...
You might be onto something. Even without colour interlace in place (cyan and light red exchanged between even and odd rasters every frame, same with purple and green), many colours already show up slightly different on even, and odd lines. That might be exaberated if only even, and/or odd lines of one colour are shown.
Looking sharper, the text screen indeed shows, that border and background colour vs. the reverse video bit are not updated within the VIC chip at the same time!! At first the border/background colour are changed, (not quite) obeying the character boundary; and then 1 or 2 pixels later, the reverse video bit (one machine cycle are 4 pixels). Indeed good food for thought for the VICE team ...
Finally, the version at the bottom left had been most probably exposed too short, showing only one of the two alternate frames.
I really must get my VIC out of the closet.
Final Edit: The VICE 2.1.16 beta indeed shows the border/background change shifted by one pixel, and the reverse video bit change takes effect 2 pixels later! I had turned on reverse video by chance when I defined the outer border, with bit 3 clear. This is pretty close to carlsson's photos.
Maybe I can live with that 1 pixel offset ...
I must confess, "problem". The timing on your PAL VIC also is shifted slightly to the right. Darn. There go my plans using horizontal raster splits to create the Archon board, or the like. The raster engine already is timed out to one machine cycle. I truly expected them to obey the character boundaries. How am I supposed to shift the timing 1 or 2 pixels to the left again? Do other VIC-20's show the same timing?Mike wrote:The newest VICE beta has yet another problem. Here, the splits don't anymore happen on character boundaries, or in the half of each character, but somewhere else.
Black and white in programming? Hummm... dunno.
The way that I know of disabling the color information is by disconnecting pin 2 of the 6560, possibly with a switch.
Disabling the color information has the added benefit of making the color appear as shades of grey on a much sharper display.
Yep. That's what I also suggested in one of my posts above. However, this would incur a hardware change, and make that VIC "nonstandard" - in the same way as those VIC's, which carry piggyback chips to fill $0400 .. $0FFF, making that memory also available to the VIC chip.eslapion wrote:The way that I know of disabling the color information is by disconnecting pin 2 of the 6560, possibly with a switch.
Granted. However, IMO Jeff just wanted to desaturate the colour display - he didn't expect a sharper display. I thought up a way by mixing complementary colours, both through raster line interlace, and time interlace.Disabling the color information has the added benefit of making the color appear as shades of grey on a much sharper display.
That experiment showed up with - for me - unexpected and interesting internals about the VIC chip timing, which the VICE team now seemingly has the emulation got quite near to.
