metalfoot76 wrote:For the load block, does it work like the C64 equivalent routine, where you can force the exact load location by passing parameters through 781/782 (lb/hb)?
Yes. The KERNAL jump table of VIC-20 and C64 was made for exactly this purpose. Even though the routines in ROM might be placed at slightly different addresses, the jump instructions in this table point to their place.
I found though there's a different behaviour of KERNAL for tape and disk, so it might be sensible to reprise this tip a bit and include the effect of different secondary addresses:
SAVE memory block:
SYS57809(N$),<device>:POKE193,<start_lo>:POKE194,<start_hi>
POKE780,193:POKE781,<end_lo>:POKE782,<end_hi>:SYS65496
or 'SYS57809(N$),<device>,0'. <start> is inclusive, <end> is exclusive, N$ contains the file name. This should actually be the standard method for saving memory blocks. For disk, it makes no difference to the following method, but on tape only this one allows to load the block back to a different address it was saved from.
SAVE memory block (and force load address on tape):
SYS57809(N$),<device>,1:POKE193,<start_lo>:POKE194,<start_hi>
For disk, effect is same as above. For tape, this forces to load back the back to the same address it was saved from, regardless what secondary address is given with the load command!
LOAD memory block ('relative' or 'relocating' load):
SYS57809(N$),<device>:POKE780,0:POKE781,<start_lo>:POKE782,<start_hi>:SYS65493
or 'SYS57809(N$),<device>,0'. Load file to address <start>. This only works as intended unless the file had been saved on tape with 'force load address'. In that case, the load address on tape takes precedence!
LOAD memory block ('absolute' load):
SYS57809(N$),<device>,1:POKE780,0:SYS65493
Load the file to the same address it was saved from.
