Gobble!
Gobble!
For the past few weeks, I have been attempting to debug a VIC-20 type-in called Gobble! by Tim Parker (1983) in order to contribute to this fine forum. Unfortunately, it will not work under VICE. Also, it seems I can't add attachments. Should I post the code here? If not, where and how?[/list]
http://www.mdawson.net/files/gobble/
I noticed the first error is because you put zeros instead of oh's in an OR.
The second was an incomplete line.
- Mayhem
- High Bidder
It's all fixed now. The joystick routine has errors in it, which I fixed and now it works as both joystick and keyboard which the original would not do.
http://www.mdawson.net/vic20chrome/vic2 ... gobble.prg
Just problems with Zeros and Ohs, and you need to be space exact.
Were you using CBM Program Studio? as you need to enter text in lower case in that, otherwise it comes out as garbage on a real vic20.
Nice looking game - looks like the same maze generating algorithm I used for my mini game - Diamond Hunt (marking the intersections with @,A,B,C,D)
I had not heard of that magazine befor either, I will looking forward to looking at some scans of it.
Android Tablet running Frodo 64 emulator running VIC 20 emulator....
