Just noticed something new about Japanese made VIC-20s.
Hey!
I just noticed a small, but neat physical detail concerning the early VIC-20 with the PET style keyboard. (These are the VIC-20s that were made in Japan and the same probably applies to the VIC-1001 - can anybody check?)
The white plastic case of my early Japanese made VIC-20 is perfectly smooth. All later ones that I own (USA and CANADA made) have a granular, sandy embossed texture on the white plastic. I compared them very closely, but that was the only difference I could see.
This corresponds with the difference of the original VIC-1540 and the (white) VIC-1541. The former has smooth plastic, while the latter has a slight sandy embossed texture.
That's weird. I compared my two prong VIC with my DIN VIC and they both were had granular textures. The 2-prong had less evident embossing than the DIN VIC, but it was still there. Whereas the Japanese PET key VIC was absolutely smooth (as glass). No granularity at all.
What's also weird is that you say that your 2-prong is taller than your DIN. I think a few years ago we (here) did a comparison, and found the opposite (there is a thread here somewhere). The DIN VIC (which is the Cost Reduced VIC), uses the same mould as the C64, while the earlier VIC's used their own, original mould for the plastic cases. But maybe the size difference is the other way 'round and I'm mis-remembering.
2-prong on left, CR/DIN VIC on right in image above.
The other difference you should see between 2-prong VICs and original VICs is the presence of a "dimple" above the cartridge port on the later ones. This is further proof that they were using a modified C64 case mould, because this dimple corresponds to the place where the RF RCA output would be on a real C64.
To further cloud the matter, 64s come in two heights as well so it can't just be a chronological thing. I much prefer the shorter models and it took me a while to make sure that both my 64 an VIC-20 (and backups of each) were the right kind and in the right condition.
- Pedro Lambrini
Just for the record my 2 prong VIC has a slight granular effect too. So that's at least 5 different casings?
1. Smooth finsih, no dimple
2. Grainy finsih, no dimple
3. Taller casing
4. Grainier finish, dimpled
5. Shorter casing
I wonder if there are others that are variants of the above...I only have 2 VIC's, both exactly the same. Does anybody have a few to compare? It would be interesting to see.
3. Taller casing
5. Shorter casing
I don't think points 3 and 5 are exclusive of the rest though. So I wouldn't classify them as separate case types.
Unfortunately, the grainy texture is very difficult to post in photographs. It's very fine, and JPEG compression helps erase it.
DigitalQuirk, could you confirm whether or not your 2-prong VIC is actually smooth as glass (no trace of granular texture at all)?
Okay, that would be the same as my (non Japanese) 2-prong VIC's then. It's smoother than my later CR/Rainbow VICs, but not as smooth as the Japanese made one with PET keys. Your's is probably not Japanese made either, eh?DigitalQuirk wrote:It is not smooth as glass; but it is very noticeably smoother than my CR Vic 20. A close inspection of the 2 prong Vic 20 reveals a very slight texture.
When I put the Japanese made one with PET keys beside it, the difference is clear....absolutely not the slightest trace of texture on the Japanese one.
Here's my theory:
1. Japanese made 2-prong VICs/VIC-1001's with PET keys: no texture at all.
2. Early N. American made 2-prong VICs without PET keys: light texture
3. Late model CR VICs with DIN power plug and rainbow logo: very noticable granular texture, like early C64s.
- Pedro Lambrini
Maybe it's just the PAL CR model that is smaller then?
£799.99 was the stipulated Buy It Now price. It's no longer there so it must have been either sold or withdrawn. I find it hard to believe that someone would even want to sell such an item.gklinger wrote:That is absolutely insane. Seriously.English Invader wrote:I saw one of the original PET keyboard VICs on e-bay a few weeks ago. It went for about £800.
