Vic 20. + & Del keys
Vic 20 Item Exchange
Sonic
Postby Sonic » Mon Jan 01, 2018 7:51 am
Any one have spare + and Del keys for sale ??
Sonic
Re: Vic 20. + & Del keys
Postby Sonic » Thu Jan 04, 2018 5:02 am
Also 2 key plungers
Postby srowe » Thu Jan 04, 2018 7:04 am
You need to mention which of the 3 different keyboards you have.
Postby eslapion » Thu Jan 04, 2018 7:56 am
srowe wrote:You need to mention which of the 3 different keyboards you have.
Sonic also posted on Amibay about this. He has the 'microgramma' keyboard. This one came out after the PET style keyboard but before the one which uses C64 style pegs and keys.
It is the only keyboard I know which has 'suction cups' inside.
Sonic
Postby Sonic » Fri Jan 05, 2018 4:45 am
Thank you eslapion
This Vic 20 is becoming a headache :oops: :D
Postby eslapion » Fri Jan 05, 2018 9:37 am
Sonic wrote:Thank you eslapion
It may turn out to be easier for you to completely change the keyboard.
The type of keyboard you have and want to fix is a bit of a rarity. VIC-20s are perfectly electrically and physically compatible with C64 and C64c keyboards.
Sonic
Postby Sonic » Fri Jan 05, 2018 7:15 pm
That is what it looks like i'll be doing... Thanks eslapion
Sonic
Postby Sonic » Fri Jan 05, 2018 7:41 pm
eslapion is the keyboard with the yellowish Function keys similar to the ones i need ??
Postby srowe » Sat Jan 06, 2018 3:28 am
The keyboard on the left, second from the bottom appears to be a Eurostile keyboard. Eslapion said
but the PET-style keyboard was the Microgramma one, the 'middle' one is the Eurostile.
Take a look at
http://sleepingelephant.com/denial/wiki/index.php?title=Keyboard
look carefully at the keys with words ('RESTORE', 'RETURN') the size of the borders varies noticeably.
Postby eslapion » Sat Jan 06, 2018 6:12 am
Sonic wrote:eslapion is the keyboard with the yellowish Function keys similar to the ones i need ??
I look at the typeface used on the return key and I would say yes.
srowe wrote:The keyboard on the left, second from the bottom appears to be a Eurostile keyboard.
You are correct. My mistake.
Sonic
Postby Sonic » Sat Jan 06, 2018 8:05 am
Thank you eslapion & srowe for your help.. Now to contact the seller of the keyboards :D
Sonic
Postby Sonic » Sat Jan 06, 2018 8:27 am
Done deal guys got the Keys & 2 plungers posted for $17 aud..
Postby srowe » Sat Jan 06, 2018 9:09 am
Let's hope they're the right ones. Eurostile keyboards are uncommon according to Giacomo's register, would be great for you to salvage one.
http://cbmvic.net/registry
Sonic
Postby Sonic » Sat Jan 06, 2018 9:19 am
srowe wrote:Let's hope they're the right ones. Eurostile keyboards are uncommon according to Giacomo's register, would be great for you to salvage one.
I managed to sms (txt) the seller with my pics i took with my Galaxy S5 and he assured me those are the keys in question and the plungers.. The plungers are exactly the same as mine, the C64 ones are much longer in length....
Sonic
Postby Sonic » Tue Jan 16, 2018 12:22 am
Plungers and Keys have been found :D 8)
Return to “Buy, Sell, and Trade”
Who is online
