FOR SALE: VIC20 FULL-RAM expansion cartridge +37K RAM with RESET!
Vic 20 Item Exchange
MCes
Re: FOR SALE: VIC20 FULL-RAM expansion cartridge +37K RAM with RESET!
Postby MCes » Sat Jul 15, 2017 2:59 am
MCes wrote:
vicist wrote:This really is a great little card. :D
Thanks MCes.
Thanks Vicist,
I'm happy for your enthusiasm in discovering the potentiality of your "new" VIC20 system...
If I remember well the RAM into i/o areas is (now) out of VICE possibilityes.... the real world win!
Try the attached file, it should be the SJLoad $98 modified to be started by "SYS40000", an more mnemonic address....
sjl$98-SYS40000.zip
SJL 07 $9800 SYS40000
(1.27 KiB) Downloaded 14 times
Errata corrige:
the file before is without header, the follow one is ready to be put onto a disk, or on VICE.
(thanks for info about VICE, now I'll download a newer version!)
Pay attention: NOT SYS4000 but SYS40000 (four times zero)
sjl$98-SYS40000.zip
“Don’t argue with idiots because they will drag you down to their level and then beat you with experience” (Mark Twain ?)
MCes
Postby MCes » Sun Jul 16, 2017 2:54 am
A question:
SJLoad work only on PAL VIC20 or on NTSC too?
About comparing Tokra $98C40-assembled SJLoad version and my $9800 (SYS40000) assembled version:
Tokra's one is a smaller file (less than 1k) and use only I/O3 area (I/O2 free), but it's limited (no SJ-save, no declaring start-stop address....)
My file is regular size and has all features of standard $98 assembled version and when you start it will be writed "SJLOAD V07 SYS40000",
but it need I/O2+I/O3 area
Option that I used:
SJSAVE = 1                              ; 0 = Don't compile SJsave routines   (LOAD only)
                                        ; 1 = compile SJsave routines
BASIO = 1                               ; 0 = Don't compile basic IO routines (LOAD/SAVE only)
                                        ; 1 = compile basic IO routines
PRINTADDRESS = 1                        ; 0 = Don't print start/end address
                                        ; 1 = print start/end address
LOADPARAMS = 1                          ; 0 = Don't compile with additional LOAD parameters
                                        ; 1 = compile with additional LOAD parameters
SAVEPARAMS = 1                          ; 0 = Don't compile with additional SAVE parameters (if SJSAVE == 1 )
                                        ; 1 = compile with additional SAVE parameters (if SJSAVE == 1 )
; This option works if PRINTADDRESS = 0 ONLY
PRINTMESSAGE = 0                        ; 0 = Don't print SAVING/LOADING Message
                                        ; 1 = print SAVING/LOADING Message like standard kernal routines
MCes
Postby MCes » Fri Jul 21, 2017 3:42 am
only 5 pieces still available!
MCes
Postby MCes » Mon Oct 02, 2017 4:43 am
only 4 pieces still available!
MCes
Postby MCes » Fri Dec 01, 2017 3:03 pm
last price: 29€
MCes
Postby MCes » Tue Jan 30, 2018 1:20 am
1 sold locally
3 pieces available
Return to “Buy, Sell, and Trade”
Who is online
