ROM 2364 substitute: EPROM 27HC641
Vic 20 Item Exchange
MCes
Post by MCes »
27HC641 EPROM,if specifically programmed, are pin compatible with 2364 ROM.
This Eprom can replace the old Commodore 8K ROM in VIC20, C64, SX64, 1541, many game cartridges,ecc....
A lot of Commodore computers, drivers, cartridges use the 2364 ROM!
EPROM 27HC641 don't need a particular voltages for programming, so it's normally supported by programmers.
The only differences between 2364 and 27HC641 are 3 address pins swapped, consequently it have to be programmed through a converter-socket (into pic) OR it has to be programmed with a manipulated ".BIN" file that exchange the address pins.
I can program it (correctly) for you, or manipulete and resend yours .BIN file.
If you are interested I can program the ROM with the image that you supply to me but remember that I make only the programming service: you remain the only responsable for eventual software copyright/royalty/licence/ecc...
Some ideas about 8K ROM implementations: http://sleepingelephant.com/ipw-web/bul ... =11&t=8434
Price (without PPfees and sending):
5€/pcs unprogrammed,
20€x 5pcs unprogrammed
6€/pcs programmed,
25€x 5pcs programmed
fabri.l
Re: ROM 2364 substitute: EPROM 27HC641
Post by fabri.l »
Hi. I'm new here. Are these still available? I'm doing some repairs and, for lack of a more genuine option (read: original ROM chips), I think these are my best option.
MCes
Post by MCes »
Yes, they are still available.
I will be more detailed after week end
