SmartReset - Quick & Secure Commodore 64 & VIC-20 Reset Button
Vic 20 Item Exchange
Oge_user
Post by Oge_user »
INTRODUCTION:
It is a well known fact that the lifespan of our Commies is strongly influenced by how many On~Off cycles are performed on each machine. SmartReset surely helps our Commodores lasting longer.
PICTURES:
INSTRUCTIONS:
• Insert/Remove SmartReset only when the machine is turned off.
SPECIFICATIONS:
• Compatible with all revisions of both Commodore 64 and VIC-20;
• PAL/NTSC.
SMARTRESET PLUS:
Improve the reliability of your machine with SmartReset Plus (Optional Internal Add-On).
• Decoupling capacitors paralleled to both 9VAC and 5VDC lines clean up current flowing into the machine;
• Filtering works regardless of the type and model of Power Supply used;
• Positively affects SID and VIC-II functionality.
PRICE:
SmartReset:
€16,00
SmartReset Plus:
€20,00
SHIPPING:
Europe:
€6,20
Outside Of Europe:
€7,40
F.A.Q.:
A: I have a C64G~C64C. Will SmartReset work?
R: Yes. It will work everywhere.
A: What happens if I insert SmartReset while the machine is on?
R: Nothing. But is recommended to insert it while the machine is turned off.
A: What happens if I insert SmartReset upside down?
R: Nothing. In that case, turn off the machine and insert SmartReset correctly.
A: Why should I use SmartReset Plus?
R: If you want something of higher quality. Or, rough and simple, if you are using a cheap source for your +5VDC line and desire to filter up the whole current rail. Be it a Commodore Power Brick or a Wall-Wart.
A: I have a VIC-20. Will SmartReset work?
R: Uhm... Yes. SmartReset Plus will be effective as well.
A: How much is delivery for X2 (two) SmartResets?
R: Identical. Shipping cost won't increase.
