WANTED: Dead Vic-20 motherboards
- Website: http://www.jagmod.com
AFAIK, Digikey also sells connectors with the 90 degrees bend.JagMod wrote:I want the cartridge port with the 90 degree bend in the leads.
All I can find new are the straight ones.
However, there is more than one brand. I remember EDAC and Vector.
It is possible only one brand offers the connector with the bend.
BTW, I have a small stockpile of C64 cart port connectors with the 90 degrees bend right here...
