EightBall - New Programming Language
Bobbi
Occupation: Programmer
Post by Bobbi »
I have been doing a bit more work on my little programming language interpreter project and thought that maybe it was time to let some other people play with it. This started out as a VIC-20 project (VICScript) but now supports C64 and Apple IIe/c as well. Accordingly I renamed it to EightBall "The Eight Bit Algorithmic Language".
It is still a work in progress.
Source code, executables, disk images and documentation at https://github.com/bobbimanners/EightBa ... /Eightball
Here is a sample program, to give you a flavour:
' Sieve of Eratosthenes
' Globals
byte nr = 10
word n = nr * nr
byte A[n] = 1
pr.msg "Sieve of Eratosthenes ..."; pr.nl
call doall()
end
sub doall()
  call sieve()
  call printresults()
return 0
sub sieve()
  word i = 0; word j = 0
  for i = 2 : (nr - 1)
    if A[i]
      j = i * i
      while (j < n)
        A[j] = 0
        j = j + i
      endwhile
    endif
  endfor
return 0
sub printresults()
  word i = 0
  for i = 2 : (n - 1)
    if A[i]
      if i > 2
        pr.msg ", "
      endif
      pr.dec i
    endif
  endfor
  pr.msg "."
return 0
Kweepa
Occupation: Game maker
Re: EightBall - New Programming Language
Post by Kweepa »
Pretty cool...
Can the interpreted language be compiled?
It looks like it might make fast code since you can declare bytes :)
Bobbi
Post by Bobbi »
Right now I am interpreting the text directly, which is slow. However it is quite convenient to be able to load and save ASCII files and exchange them between systems this way (with some help from petcat!)
I am planning on moving to a tokenized representation, which should speed things up. I am also thinking to implement a virtual machine and a simple compiler targeting it. I am open to suggestions as to the best approach ... obviously, memory is tight. This should be a fun project over the winter months, and I guess I will learn a lot about compiler development :)
First though, I want to stabilize this release, add multidimensional arrays and squash some bugs.
Bobbi
Post by Bobbi »
Took longer than I thought, but there is a new release of EightBall on my GitHub page:
https://github.com/bobbimanners/EightBall
There is now a
comp
command which compiles the language to bytecode for the EightBall VM (also new with this release.) The compiled code runs much faster than interpreted code (even with the totally unoptimized VM I have at present.)
Documentation is included in the wiki on the GitHub page.
Enjoy!
Bobbi
Post by Bobbi »
Fixed a couple of bugs. Latest version is v0.52.
Bobbi
Post by Bobbi »
v0.76 is now available from https://github.com/bobbimanners/EightBall
There are numerous small improvements. The virtual machine has been optimized somewhat and compiled bytecode now runs a good deal faster than before.
dr.geek
Post by dr.geek »
Looks very interesting - i have been looking at the quetzalcoatl compiler which can produce prg's for an actual VIC. Do you see Eightball getting to this point?
