machine language problems and question
vicassembly
Post by vicassembly »
I have the situation where I am using relative X addressing and want to be more 'generic.' Here is my situation.
I want to write 1 routine that operates on multiple vectors of numbers. For example:
sprite1: .byte 1,2,..,32 (number of bytes)
sprite2: .byte 1,2,..,32
spriten: .byte 1,2,..,32
I wrote the routines to use sprite1 when developing it. I do all sorts of activities where I use nomenclature:
LDA SPRITEDATA1+$10,X or LSR SPRITEDATA1+$08,X etc. etc.
This does not lend itself to being reused very easily. Does anyone have ideas how I might make this more generic? I thought about creating vetors:
splo .byte lobyte_sprite1, .. lobyte_spriten
sphi .byte hibyte_sprite1, .. hibyte_spriten
This way I could load those into a v lo/hi zero page variable and access via:
LDA (lovar),Y
This still doesn't quite match the ,X scheme I had before. Thoughts?
Second question. Should be an easy one.
Are these two equal?
LDY #$00
BEQ @JUMP
LDY #$00
CPY #$00
BEQ @JUMP
I know that using LDA it would be equal.
Thanks.
Jonathan
Re: machine language problems and question
vicassembly wrote:Are these two equal?
LDY #$00
BEQ @JUMP
LDY #$00
CPY #$00
BEQ @JUMP
Yes, LDY modifies the Z flag so the CPY is not needed.
Website: http://hugbox.org/
My two cents: go for the LDA (vector),Y – I guess the ,X scheme already gave you a terrible mess, didn't it?
