Sega Light Phaser
cbmeeks
Website: http://meeks.co
Occupation: Code Monkey
Sega Light Phaser
Post by cbmeeks »
Hello all.
I got a Sega Light Phaser for my birthday and I thought it would be fun to see if I could get it to work on the VIC-20.
The following program doesn't really work:
10 H=36870
15 V=36871
20 PRINT PEEK(H), PEEK(V)
30 GOTO 20
It just prints 129 and 0. Every now and then, when I press the button, one of the axis will show some random, odd number.
So, how do I program this thing? :-D
BTW, I realize that I need some type of contrasting white image or something similar. Not 100% sure how the Sega version compares to the NES version of light guns.
But I've been experimenting with it by shooting at really bright lights, dark areas, etc.
Cat; the other white meat.
GreyGhost
Re: Sega Light Phaser
Post by GreyGhost »
If your keyboard is still working and you have disk access, consider yourself lucky. IIRC, Sega peripherals have voltage on a pin that Commodores don't. Might wanna do some research to make sure.
Rob
Post by R'zo »
GreyGhost wrote:If your keyboard is still working and you have disk access, consider yourself lucky. IIRC, Sega peripherals have voltage on a pin that Commodores don't. Might wanna do some research to make sure.
There are adapters for plugging sega controllers into comodores that cut out the voltage pin.
http://www.64hdd.com/64jpx/64jpx.html
I'very seen other but I can't seem to find them at the moment.
Ultimately it would be simple to by a plug, leave out the voltage pin and make your own adapter.
cbmeeks
Post by cbmeeks »
I've made that adapter before for my C64 for Genesis controllers.
I don't think that is needed for Sega Master System controllers though. I could be wrong.
I believe the Light Phaser is just a SMS controller with the directionals not connected.
FriedOrange79
Occupation: Student
Post by FriedOrange79 »
I've been using a Sega Master System controller with my VIC-20s for a while now and it doesn't seem to have caused any problems. Is the issue to do with the second button that these controllers have?
I also got a Light Phaser recently and wondered about using it with the VIC, since the light pen I attempted to build earlier gave similar rubbish results!
Post by R'zo »
FriedOrange79 wrote:I've been using a Sega Master System controller with my VIC-20s for a while now and it doesn't seem to have caused any problems. Is the issue to do with the second button that these controllers have?
The mega drive (genisi) has an extra voltage pin that can blow out your chips, the master system controllers are fine.
ONLY the plain old regular 2-button pads are safe... somewhat
lightgun is NOT - but it can likely be rewired to work with vic20 easily, see here
