Help converting numbers onto Char in ML
jalavera
Postby jalavera » Sun Mar 19, 2017 1:58 am
Hi!
I'm programming a little in ML but I don't know what's the way to convert a byte number in a memory location to its converted string writable in screen.
For example if I PEEK nnnn memory we can use: LDA nnnn. But how can I print the acculator value to screen? I know internal $FDD2 routine, but this write the ASCII value not the string one.
Thanks!
Re: Help converting numbers onto Char in ML
Postby srowe » Sun Mar 19, 2017 3:06 am
Depending on what base you want it's either quite easy or a little complicated.
For printing in hex the bytes simply map on to pair of characters to display. So $1234 comes out as "1" ($31), "2" ($32), "3" ($33) and "4" ($34). Values above 9 have to be handled as there's a 'gap' between "9" ($39) and "A" $(41). Using blocks of 4 shifts to normalize each nibble you can do something like
PRINTHEX16
   LDA STAL+1      ; get high byte
   JSR PRINTHEX8      ; output as hex digits
   LDA STAL      ; get low byte
PRINTHEX8
   PHA         ; save value
   LSR         ; shift top nibble ..
   LSR
   LSR
   LSR         ; .. into bottom nibble
   JSR LAD82      ; output most significant nibble as hex digit
   PLA         ; restore value
   AND #$0F      ; mask off top nibble
LAD82   ORA #'0'
   CMP #'9'+1
   BCC LAD8A      ; numeric, output it
   ADC #$06      ; make hex digit
LAD8A   JMP CHROUT      ; output character to channel
Printing a number as decimal is more complex because you need to do successive divisions by ten. You can find examples of doing multibyte division in most 6502 assembly books.
If all you want is to print a 16 bit unsigned number you can call the BASIC PRTFIX ($DDCD) subroutine, load .A with the MSB and .X with the LSB.
jalavera
Postby jalavera » Sun Mar 19, 2017 10:12 am
Thanks. I will try!
Where can I found this Basic PRTFIX in detail? I never listened and read before. I suppose there are others which can be used.
Postby srowe » Sun Mar 19, 2017 10:56 am
jalavera wrote:Thanks. I will try!
There are many BASIC and KERNAL routines which can be used in your own programs. I have a dissassembly of the VIC-20 ROMs here
http://eden.mose.org.uk/gitweb/?p=rom-reverse.git;a=blob;f=src/basic_kernal.asm;hb=HEAD
which are commented. PRTFIX is convenient but not efficient. It converts the integer into a floating point number then uses the floating point print routines.
Postby Mike » Sun Mar 19, 2017 3:04 pm
srowe wrote:Printing a number as decimal is more complex because you need to do successive divisions by ten.
It is also possible to use the decimal mode of the 6502 to build up a number in BCD code from its binary representation and then use your example routine to print HEX numbers: http://6502.org/source/integers/hex2dec-more.htm.
Those routines need to be used with caution on the VIC-20 though: the standard IRQ handler in the KERNAL doesn't issue a CLD as first instruction and this can lead to problems with interrupt routines that don't take the decimal mode into account. Unless the IRQ is adapted, this means these conversion routines must be run with interrupts disabled.
Also, the number conversion can implement the division as table-driven repeated multibyte subtractions. That works amazingly well even in the presence of mixed bases, as it's the case with a clock display from the jiffy timer: "Display of TI$ in border (unex. or +3K)".
... P.S. see this thread, "best way to display decimal number?", for a nice déjà vu. :mrgreen:
wimoos
Occupation: farmer
Postby wimoos » Mon Mar 20, 2017 5:51 am
Printing signed 16-bit integers (where the high bit of the msb denotes the sign):
   LDA msb
   LDY lsb
   JSR $D391
   INY
   JMP $DDD7
Regards,
Wim.
Kweepa
Occupation: Game maker
Postby Kweepa » Mon Mar 20, 2017 8:48 am
Codebase64 has a great collection of efficient 6502 snippets.
http://www.codebase64.org
For example (to answer your question):
http://www.codebase64.org/doku.php?id=b ... ii_routine
jalavera
Postby jalavera » Tue Mar 21, 2017 6:29 am
After testing routines you suggest I think Kweepa's one is what I was looking for: 1 byte (0-255) in decimal using .A (ones), .X (tens), .Y. (hundreds) registers. When combined it prints YXA on screen. It's like PRINT PEEK (1234).
Many thanks to all of you.
Return to “Programming”
Who is online
