hi out there, i have an emergent question.
if i chance the colors in an unexpanded vic with POKE 36879,X
and i try this on 32k expanded vic is it the same or are there differences ???
and if there are, how can i calculate it for my basic program
thanks 4 help
POKE unexpand ,POKE 32k ???
Re: POKE unexpand ,POKE 32k ???
Put the question the other way round: why do you think there could be any differences in the behaviour or location of that register between unexpanded and 32K expanded VIC-20s?
That notwithstanding the obvious suggestion to just try it out, on real h/w or in VICE.
36879 changes the border/foreground colours and is unaffected by additional ram.
I think you're getting this confused with screen colour memory which moves when ram is added.
unexpanded = 38400 - 38905
8k+ expanded = 37888 - 38393
So, poke 38400,2 would make the top left character red on an unexpanded Vic and poke 37888,2 does the same thing on a Vic with 8k or more of added ram. The difference is 512.
- Occupation: OKERVALLEY
thanks for fast answering too a noob since 1982...the fault was the computer i build it on with a vice emulation...
now ELIZA2016 works fine as prefered. thanks n regards.
