synths by r'zo
synths by r'zo
Post by R'zo »
I plan on writing a good hand full of various synth programs for the Vic. Some for use with the vic midi cart, some for use with the c=64 keyboard overlay as well as others. I will be posting them all here for discussion so I don't overrun the forum with post on my synths.
Re: synths by r'zo
Post by R'zo »
MICRO VICIOUS
Features
-works with c=64 keyboard overlay
-gives 2 octave monophonic playable control over the vics 4 voices
-edit individual controls for the tone, octave and tune of all 4 voices
-works without memory expansion
-bypasses the keyboard buffer and goes strait to peek(197) for faster key reaction
-(edit)-works with pal and ntsc
download-Micro Vicious
This program will be should be easy for me to translate for use with midi cart. All it should require for both in and out is changing a few numbers and addresses.
RobertBe
Vic 20 Elite
Re: synths by r'zo
Post by RobertBe »
Oh, time to dig out the keyboard overlay! :)
Thanks,
Robert Bernardo
Fresno Commodore User Group
July 30-31 Commodore Vegas Expo v12 -
http://www.portcommodore.com/commvex
Re: synths by r'zo
Post by R'zo »
RobertBe wrote:Oh, time to dig out the keyboard overlay! :)
I would really like know how it works out with the overlay. I do not have one yet.
RobertBe
Vic 20 Elite
Re: synths by r'zo
Post by RobertBe »
Oh, very well. I won't be back home until Wednesday, and then I can search for the overlay.
Truly,
Robert Bernardo
Re: synths by r'zo
Post by R'zo »
I found a bug playing around with this on my vic last night. F#2 has no reaction. I had only tested this in emulation and the key layout gets a little funny. It was an easy miss but will also be an easy fix. I should be able to have it fixed and my links updated within a couple of days. Aside from that, she plays beautifully on hardware. The key reaction is even better than I expected. No noticeable latency, smooth reaction and that wonderful raw vic sound.
Re: synths by r'zo
Post by R'zo »
It didn't take as long as I thought. Links have been updated.
Micro vicious
Re: synths by r'zo
I tried this, but could not figure out how to exit edit mode once I was in it. I did try pressing F7 again.
Re: synths by r'zo
Post by R'zo »
ral-clan wrote:I tried this, but could not figure out how to exit edit mode once I was in it. I did try pressing F7 again.
Press 9 (c#2) to exit edit mode.
I originally had f7 to exit edit mode. I had a simple problem where f7 would enter edit mode and then exit right back out of it. I could have worked around it but I wanted to keep this version of the program as short and simple as poosible so I just used a different key for the exit.
Re: synths by r'zo
Post by R'zo »
I looked at the memory usage of Micro Vicious the other day and discovered that it only uses 2k memory to run. This leaves me a good amount of space to buff the program up a little more and still fit into the unexpanded vic.
goals for Micro Vicious 2.0
-center display screen
-set 1 key to toggle edit and play mode
-load/save features
-an added graphic in the display to signify play or edit mode
I am more than open at this points to suggestions.
Re: synths by r'zo
Post by R'zo »
MICRO VICIOUS 2.0
I have finished version 2 and accomplished all the added features that I projected in the last post. It is a little more user friendly. I have now tested it on hardware with the keyboard overlay and it works beautifully.
This .zip folder-micro vicious 2.0.zip contains the micro vicious 2.0.d64 disk image, a printable instruction manual and a type-in version with type-in instructions.
