V-FORTH - Forth-83 for the VIC
Re: V-FORTH - Forth-83 for the VIC
hello thanks for the help.
wonderfull.
greeting
wonderfull.
greeting
I've just added support for multicolour bitmap graphics.
Hi good afternoon.
thanks, is a great thing you have put together.
thanks.
greeting
thanks.
greeting
Hi good afternoon.
how can you compile the vforth in windows 10?
what do you have to download for windows so that the make runs?
cpp -P -w -x assembler-with-cpp
I already have python 3.
thanks.
greeting
thanks.
greeting
- pixel
- Website: http://hugbox.org/
That would be GNU Make, ported by DJ Delorie.
Am very excited about the new 4.0 version!
hello, thanks for the info.
greeting
greeting
It's a very long time since I ran UNIX tools on Windows.
I think this is a list of what you need:
- make
- gcc (for cpp)
- expand
- python3
- vice (for c1541 and petcat)
Admittedly, I must have lost track about the thread topic at some time here:
Especially given that there have been quite some important bug-fixes, I'd be very interested to try out VFORTH.
Is there a document which lists the built-in words of the base system (i.e. those available without any *.FS libraries loaded)? Likewise, is there a dependency graph that lists in which order *.FS libraries have to be loaded?
... are the users of VFORTH now supposed to build it on their own? That to say, at least I could not find any hint to the most recent *.d64 release or - equivalent - a folder/directory with VFORTH.PRG and all the current *.FS libraries, which could be copied directly on a SD card.
this os the word-list :
greeting
(mod: long list put into code-tags to save on screen estate, see also wordlist.txt in vforth.git)
Word Set
! Required, nucleus
!CSP
# Required, interpreter
#> Required, interpreter
#S Required, interpreter
#TIB Required, interpreter
$CHKIN V-Forth, KERNAL
$CHKOUT V-Forth, KERNAL
$CLOSE V-Forth, KERNAL
$CLRCHN V-Forth, KERNAL
$LOAD V-Forth, KERNAL
$OPEN V-Forth, KERNAL
$PLOT V-Forth, KERNAL
$READ V-Forth, KERNAL
$READLINE V-Forth, KERNAL
$READST V-Forth, KERNAL
$RSTIN V-Forth, KERNAL
$RSTOUT V-Forth, KERNAL
$SAVE V-Forth, KERNAL
$SETLFS V-Forth, KERNAL
$SETNAM V-Forth, KERNAL
$WRITE V-Forth, KERNAL
$WRITEB V-Forth, KERNAL
' Required, interpreter
( Required, interpreter
(") Runtime
(+LOOP) Runtime
(.") Runtime
(;CODE) Runtime
(?DO) Runtime
(ABORT") Runtime
(DO) Runtime
(EXPECT)
(FIND) Runtime
(LOOP) Runtime
* Required, nucleus
*/ Required, nucleus
*/MOD Required, nucleus
+ Required, nucleus
+! Required, nucleus
+LOOP Required, compiler
+ORIGIN
, Required, compiler
- Required, nucleus
-1 Constant
-TRAILING Required, interpreter
. Required, interpreter
." Required, compiler
.( Required, interpreter
.R Controlled
/ Required, nucleus
0 Constant
0< Required, nucleus
0= Required, nucleus
0> Required, nucleus
1 Constant
1+ Required, nucleus
1- Required, nucleus
2 Constant
2! Double number, nucleus
2* Controlled
2+ Required, nucleus
2- Required, nucleus
2/ Required, nucleus
2@ Double number, nucleus
2CONSTANT Double number, compiler
2DROP Double number, nucleus
2DUP Double number, nucleus
2OVER Double number, nucleus
2ROT Double number, nucleus
2SWAP Double number, nucleus
2VARIABLE Double number, compiler
3 Constant
: Required, compiler
; Required, compiler
;CODE Assembler, compiler
< Required, nucleus
<# Required, interpreter
= Required, nucleus
> Required, nucleus
>BODY Required, interpreter; field address
>IN Required, interpreter
>LINK Field address
>NAME Field address
>R Required, nucleus
?BRANCH System, nucleus
?COMP
?CSP
?DO ANSI
?DUP Required, nucleus
?ERROR
?EXEC
?IOERR V-Forth, file I/O
?PAIRS
?STACK
?TERMINAL
@ Required, nucleus
[ Required, compiler
['] Required, compiler
[CHAR] ANSI
[COMPILE] Required, compiler
ABORT Required, interpreter
ABORT" Required, compiler
ABS Required, nucleus
AGAIN Uncontrolled
ALLOT Required, compiler
AND Required, nucleus
ASSEMBLER Assembler, interpreter
AUX.HERE
AUX.ORIGIN
BASE Required, interpreter
BASIC V-Forth, system
BEGIN Required, compiler
BL Controlled
BLANK Controlled
BODY> Field address
C! Required, nucleus
C, Controlled
C/L
C@ Required, nucleus
CATCH V-Forth, exception
CHAR ANSI
CLIT Runtime
CLOSE-FILE V-Forth, file I/O
CMOVE Required, nucleus
CMOVE> Required, nucleus
COLD
COMPILE Required, compiler
CONSTANT Required, compiler
CONTEXT System, interpreter
CONVERT Required, interpreter
COUNT Required, nucleus
CR Required, device
CREATE Required, compiler
CSP
CURRENT System, interpreter
D+ Required, nucleus; double number, nucleus
D+-
D- Double number, nucleus
D. Double number, interpeter
D.R Double number, interpeter
D0= Double number, nucleus
D2/ Double number, nucleus
D< Required, nucleus, double number, nucleus
D= Double number, nucleus
D> Double number, nucleus
DABS Double number, nucleus
DECIMAL Required, interpreter
DEFINITIONS Required, interpreter
DEPTH Required, nucleus
DEVICE# V-Forth, file I/O
DIGIT
DLITERAL Runtime
DLOAD V-Forth, file I/O
DMIN Double number, nucleus
DNEGATE Required, nucleus; double number, nucleus
DO Required, compiler
DODOES Runtime
DOES> Required, compiler
DP
DPL Uncontrolled
DROP Required, nucleus
DSAVE V-Forth, file I/O
DU< Double number, nucleus
ELSE Required, compiler
EMIT Required, device
ENCLOSE
ERASE Controlled
ERROR V-Forth, exception
EX-ERROR V-Forth, exception
EXCEPTION V-Forth, exception
EXECUTE Required, nucleus
EXIT Required, nucleus
EXPECT Required, device
FALSE ANSI
FATAL V-Forth, exception
FENCE
FILL Required, nucleus
FIND Required, interpreter
FORGET Required, interpreter
FORTH Required, interpreter
FORTH-83 Required, interpreter
FREEPGS V-Forth, system
GETPAGE V-Forth, system
HERE Required, interpreter
HEX Controlled
HLD
HOLD Required, interpreter
I Required, nucleus
ID.
IF Required, compiler
IMMEDIATE Required, compiler
INBUF
INCLUDE V-Forth, file I/O
INCLUDE? V-Forth, file I/O
INCLUDED V-Forth, file I/O
INTERPRET Controlled
IODIAG V-Forth, file I/O
J Required, nucleus
KEY Required, device
LAST Uncontrolled
LATEST
LEAVE Required, compiler
LIT Runtime
LITERAL Required, compiler
LOADD V-Forth, file I/O
LSHIFT ANSI
M*
M/MOD
MAX Required, nucleus
MESSAGE
MIN Required, nucleus
NAME
NAME> Field address
NEXTLFN V-Forth, file I/O
NEXTSA V-Forth, file I/O
NIP ANSI
NOT Required, nucleus
NUMBER Uncontrolled
OPEN-FILE V-Forth, file I/O
OR Required, nucleus
OUT
OVER Required, nucleus
PAD Required, interpreter
PICK Required, nucleus
PUTPAGE V-Forth, system
QUERY Controlled
QUIT Required, interpreter
R> Required, nucleus
R@ Required, nucleus
RAISE V-Forth, exception
READ-FILE V-Forth, file I/O
READ-LINE V-Forth, file I/O
REPEAT Required, compiler
ROLL Required, nucleus
ROT Required, nucleus
RP!
RSHIFT ANSI
S" ANSI
S->D
SAREG V-Forth, system
SAVED V-Forth, file I/O
SIGN Required, interpreter
SMUDGE
SP!
SP@ Controlled
SPACE Required, device
SPACES Required, device
SPAN Required, interpreter
SPREG V-Forth, system
STATE Required, compiler
SWAP Required, nucleus
SXREG V-Forth, system
SYREG V-Forth, system
SYS V-Forth, system
THEN Required, compiler
TIME! V-Forth, KERNAL
TIME@ V-Forth, KERNAL
TOGGLE
TRAVERSE
TRUE ANSI
TUCK ANSI
TYPE Required, device
U. Required, interpreter
U< Required, nucleus
UD/MOD
UM* Required, nucleus
UM/MOD Required, nucleus
UNTIL Required, compiler
USER Uncontrolled
VARIABLE Required, compiler
VOC-LINK
VOCABULARY Required, compiler
WHERE V-Forth, exception
WHILE Required, compiler
WORD Required, interpreter
WORDS Uncontrolled
WRITE-FILE V-Forth, file I/O
WRITE-LINE V-Forth, file I/O
X
XOR Required, nucleus
Hi good afternoon.
srowe can you please translate this into the vforth for me.
this is rs232 works in vic20.
thanks.
greeting
in basic it works:
10 open2,2,0,chr$(8)+chr$(0)
20 get#2,a$ : print a$;
30 get a$ : print a$; : if a$<>""then s$=s$+a$
40 if a$=chr$(13)then print#2,s$; : s$=""
50 goto 20
thanks.
greeting
in basic it works:
50 goto 20
No, regular users won't need to build from source. If you want make changes to the core definitions (or the CBM interface) then you need to edit vforth.fs or system.fs and rebuild.Mike wrote: ↑Thu Oct 24, 2019 11:54 am
Hi good afternoon.No, regular users won't need to build from source. If you want make changes to the core definitions (or the CBM interface) then you need to edit vforth.fs or system.fs and rebuild.
how do you do that under windows?
thanks.
greeting
I think this should work, I don't have an RS-232 setup to handfunkheld wrote: ↑Fri Oct 25, 2019 1:42 am Hi good afternoon.
thanks.
greeting
in basic it works:
50 goto 20
8 constant 1200baud
variable lfh
: open ( baud -- )
pad c! 0 pad 1+ c! pad 2 $setnam
nextlfn lfh ! 0 2 lfh @ $setlfs $open drop ;
: close ( -- )
lfh @ $close drop ;
: read-echo ( -- )
pad 256 lfh @ read-line ?ioerr
pad count type cr ;
: serial-test
1200baud open
begin
read-echo ?terminal
until close ;
Hello, thanks for your help.
When I send the data, an error message comes.
thanks.
greeting
thanks.
greeting
