Hello, there's a game to be fixed. Here's the problem:
Who wants to help me out, please contact me in private. Thanks a lot.
Game to be fixed please
- saver71
- Vic 20 Hobbyist
- Website: https://superottanta.blogspot.com
- Occupation: Advertiser
Re: Game to be fixed please
Today, I took my time to try and fix it, but failed
Apparently, lines from 280 to 300 are the critical ones, with line 280 drawing spaces. These are not only "spaces", as drawing less spaces means less stress frame (try modifying the values in for...next loop).
Thanks to whoever can explain these lines, please here and not in pm.
Without the source at hand, I can only tell that of course it is not possible to fill the most bottom-right character with a PRINT statement. If done so regardless, it will cause the screen to scroll. So most probably that character was left out by purpose, because the programmer didn't know how to circumvent this.
If this game is for unexpanded or +3K expanded VIC-20, you might try to insert the following two POKEs right after the frame has been set up: POKE8185,230:POKE38905,0
Not so, there's an example using CHR$(157)CHR$(148) on page 23 of the Programmers Ref Guide that shows how to do this.I can only tell that of course it is not possible to fill the most bottom-right character with a PRINT statement.
- saver71
- Vic 20 Hobbyist
GREAT!Mike wrote:you might try to insert the following two POKEs right after the frame has been set up: POKE8185,230:POKE38905,0
There was only POKE38905,0 and POKE8185,230 was missing. Thank you very much!
Thanks to orion70 and srowe too.
I looked it up. Well, nice! I truly assumed the screen editor would open a new line and cause the screen to scroll even in that case, though I obviously never tested it.srowe wrote:Not so, there's an example using CHR$(157)CHR$(148) on page 23 of the Programmers Ref Guide that shows how to do this.
That method can still fail however, when the current logical line had an odd number of quotes printed and thus the cursor is in quote mode. For this reason, ending the last print line one character short and placing either a final {HOME} character in that string or a semi-colon after the string, and then POKEing the bottom-right character into place will remain the preferred solution for me.
- saver71
- Vic 20 Hobbyist
Coming soon with SUPER VIC & C64 n.3.
Sidenote: I was commenting the listing because Saver71 was so kind to provide me with the source code. Next time, I invite Saver to post the source for everyone's intervention .
