srowe wrote:I've replaced the char ROM socket and basically restored the machine back to standard for now. [...] My current guess is that the BASIC ROM is faulty. I'm planning to write a program to repeatedly test it's contents.
Even though it could be a faulty BASIC ROM (I read about several cases of this in the last months) you should also take the function of the 13-input NAND and the three bus-buffers under extreme scrutiny: you don't want the data bus buffer enabled during CPU read accesses of BASIC or KERNAL ROM (or anything on the expansion port, for that matter). Even when there are no chip selects on the input side of the bus buffer (i.e., internal RAM or character ROM), it actively drives a (random) L- or H-level on its outputs which conflicts with signals on the CPU side of the data bus.
Here's a small program to check the BASIC ROM for the correct checksum of $0E8131:
1 FORT=674TO743:READA:POKET,A:NEXT:POKE36879,27:POKE783,4:SYS674
2 DATA 169,192,133,252,169,0,133,3,133,4,133,5,133,251,168,162,32,24,177,251,101,3,133
3 DATA 3,165,4,105,0,133,4,165,5,105,0,133,5,200,208,234,230,252,202,208,229,165,3,201
4 DATA 49,208,12,165,4,201,129,208,6,165,5,201,14,240,194,169,26,141,15,144,76,229,2
It runs in a loop, as soon as it detects a difference, the border turns red. Here's the source:
; $05/$04/$03 := high/mid/low-byte of checksum
; $FC/$FB := ZP-pointer into BASIC ROM
.02A2 A9 C0 LDA #$C0
.02A4 85 FC STA $FC
.02A6 A9 00 LDA #$00
.02A8 85 03 STA $03
.02AA 85 04 STA $04
.02AC 85 05 STA $05
.02AE 85 FB STA $FB
.02B0 A8 TAY
.02B1 A2 20 LDX #$20
.02B3 18 CLC
.02B4 B1 FB LDA ($FB),Y
.02B6 65 03 ADC $03
.02B8 85 03 STA $03
.02BA A5 04 LDA $04
.02BC 69 00 ADC #$00
.02BE 85 04 STA $04
.02C0 A5 05 LDA $05
.02C2 69 00 ADC #$00
.02C4 85 05 STA $05
.02C6 C8 INY
.02C7 D0 EA BNE $02B3
.02C9 E6 FC INC $FC
.02CB CA DEX
.02CC D0 E5 BNE $02B3
.02CE A5 03 LDA $03
.02D0 C9 31 CMP #$31
.02D2 D0 0C BNE $02E0
.02D4 A5 04 LDA $04
.02D6 C9 81 CMP #$81
.02D8 D0 06 BNE $02E0
.02DA A5 05 LDA $05
.02DC C9 0E CMP #$0E
.02DE F0 C2 BEQ $02A2
.02E0 A9 1A LDA #$1A
.02E2 8D 0F 90 STA $900F
.02E5 4C E5 02 JMP $02E5
(POKE783,4 is used to SYS into the code with interrupts disabled and decimal flag clear - otherwise the DATA would have overflown into a fourth line )
