Reverse engineering KERNAL source
It would be useful to have the source for the KERNAL, along with symbol tables and headers for zero page addresses.
I've managed to get dxa to do a reasonable job, I'm now going to need to do some manual cleanup. I've used Compute!'s "Mapping the VIC" for the naming of symbols (with a few minor changes).
Has anyone come across the source for the KERNAL (original or otherwise) or should I proceed and post my copy?
buzbard
Re: Reverse engineering KERNAL source
Post by buzbard »
Yeah, here's one.
kernel_disassembly.txt
Ray..
... which not only gives the KERNAL source (beginning from $E378) but also the complete BASIC interpreter (from $C000 to $E377).
Without such a ROM disassembly, one can pretty much forget about doing things like a BASIC extension or adding extra functionality to the KERNAL like a fast loader for disk drives. The float routines inside BASIC are available at no cost, and their direct use can easily give up to 3 times speed up compared to when called from the interpreter loop ...
That's great. I think I'll update this with the symbols used in the Compute! book.
FD22
Post by FD22 »
I printed Lee's disassembly out, which meant I could physically draw trace lines through the atrocious CHRIN and CHROUT logic. Even this disassembly has a couple of comments along the lines of 'WTF?' in that code. :lol:
Once I'd actually figured-out what the hell they were doing, the substitute routines in FAST-40 came in at about 50% the size and twice as fast. :)
FD22 wrote:Once I'd actually figured-out what the hell they were doing, the substitute routines in FAST-40 came in at about 50% the size and twice as fast. :)
Well? Are there any tangible results you'd want to release?
FD22
Post by FD22 »
Still working on it - I get maybe a couple of hours a week at the moment.
Here's the core of CHROUT40, for your entertainment and sneak-peek. :)
;; Vector handler for _CHROUT
chrout40	SUBROUTINE		character output vector handler [.A, .X, .Y, Stack]
			sta _LASTKEY				; [3]	ZP save output character
			pha							; [3]	push output character in .A to Stack
			lda _DEVOUT					; [3]	ZP get output device
			cmp #3						; [2]	output directed to screen device?
			beq .screen					; [3/2]	jump to screen handler if so
			jmp _CHROUT2				; [6]	jump to KERNAL for non-screen output
; output to screen, so FAST-40 handles it
.screen		sta _F40CDRAW				; [3]	ZP set cursor undraw flag (0=no undraw, !0=undraw)
			txa							; [2]	save .X and .Y to Stack
			pha							; [3]
			tya							; [2]
			pha							; [3]
; save and disable cursor enable mode (prevent IRQ redrawing cursor mid-way through render)
			lda _CRSRMODE				; [3]	ZP get cursor enable (0=flash, !0=no flash)
			pha							; [3]	save to Stack
			lda #$FF					; [2]
			sta _CRSRMODE				; [3]	ZP set cursor enable (0=flash, !0=no flash)
; determine what character we're handling
			lda _LASTKEY				; [3]	ZP get output character
			cmp #$20					; [2]	compare with #32 [SPACE]
			bcc	.conchar				; [2/3]	less than, so a low control character
			cmp #$8D					; [2]	compare with #141 [SHIFT RETURN]
			bcc .normal					; [3/2]	less than, so normal printable character
			cmp #$A0					; [2]	compare with #160 [INVERSE SPACE]
			bcs .normal					; [2/3]	not less than, so a normal printable character
; it's a control character, push return address and handler address to Stack
.conchar	tax							; [2]	shift character to .X for table lookup
			lda >#.alldone				; [2]	get control character return address hi-byte
			pha							; [3]	push to Stack
			lda <#.alldone-1			; [2]	get control character return address lo-byte
			lda _CONCODEH,x				; [4]	get output handler address hi-byte
			lda _CONCODEL,x				; [4]	get output handler address lo-byte
			rts							; [6]	return to control character handler
			; #TODO likely need to do something here when quote mode is on
; it's a normal printable character, output as given
.normal		ldy #0						; [2]
			sty _CRSRBLNK				; [3]	ZP set cursor blink phase off
			sty _F40CDRAW				; [3]	ZP set cursor undraw flag (0=no undraw, !0=undraw)
			ldy _CURPOS					; [3]	ZP get cursor column
			sta (_SCRNLINE),y			; [6]	write character to text buffer
; set character data address and render masks
			tax							; [2]	move character to .X for glyph index
			lda _CHARTABL,x				; [4]	get character glyph data address lo-byte
			sta .dataaddr+1				; [4]	modify data read address
			lda _CHARTABH,x				; [4]	get character glyph data address hi-byte
			sta .dataaddr+2				; [4]	modify data read address
			lda _F40CMASK				; [3]	ZP set character mask
			sta .charmask+1				; [4]	set character mask
			eor #$FF					; [2]	invert it
			sta .scrnmask+1				; [4]	set bitmap mask
; merge character data with bitmap
			ldy #7						; [2]	glyph bytes to process
.dataaddr	lda $C0DE,y					; [4]	get character glyph data byte
.charmask	and #$FF					; [2]	apply character mask
			sta .charmrge+1				; [4]	modify character/bitmap merge byte
			lda (_F40CADDL),y			; [5]	ZP indirect get bitmap byte
.scrnmask	and #$FF					; [2]	apply screen bitmap mask
.charmrge	ora #$FF					; [2]	merge glyph byte with bitmap byte
			sta (_F40CADDL),y			; [6]	ZP indirect set bitmap byte
			dey							; [2]	decrement glyph byte counter
			bpl .dataaddr				; [3/2]	loop for next glyph byte
			jsr crsrrght				; [6]	move cursor after character output
; undraw cursor before calculating new address
.alldone	lda _F40CDRAW				; [3]	ZP get cursor undraw flag (0=no undraw, !0=undraw)
			beq .recalc					; [2/3]	skip undraw if not required
			lda _CRSRBLNK				; [3]	ZP get cursor blink phase flag
			beq .recalc					; [2/3]	skip undraw if phase is off
			jsr drawcrsr				; [6]	undraw cursor
; compute new cursor draw address and set blink mask
.recalc		ldy _CRSRROW				; [3]	ZP get cursor row
			ldx _ROWMULT,y				; [4]	get multiplied value for bitmap row
			lda _CURPOS					; [3]	ZP get cursor column
			lsr							; [2]	divide by two
			tay							; [2]	shift divided column to .Y
			lda #$0F					; [2]	set mask for left character (even column)
			bcs .setmask				; [3/2]	skip switch to right character if odd
			lda #$F0					; [2]	column is even so mask for right character
.setmask	sta _F40CMASK				; [3]	ZP set character mask
			txa							; [2]	shift multiplied bitmap row to .A
			clc							; [2]	clear Carry before column addition
			adc _COLADDRL,y				; [4]	add bitmap column address lo-byte
			sta _F40CADDL				; [3]	ZP set cursor draw address lo-byte
			lda _COLADDRH,y				; [4]	get bitmap column address hi-byte
			adc #0						; [2]	add Carry
			sta _F40CADDH				; [3]	ZP set cursor draw address hi-byte
; restore cursor mode
			pla							; [4]	pull cursor mode from Stack
; restore registers, clear error flag in Carry, and exit
			pla							; [4]	pull .Y, .X and .A from Stack
			tay							; [2]
			pla							; [4]
			tax							; [2]
			pla							; [4]
			clc							; [2]	clear Carry, no error
			rts							; [6]
			ECHO "chrout40		:",[*-chrout40]d
Yawn.
Here's the *complete* source code of the library used in MG Text Edit, which should be good for some suggestions in case you got stuck with your project.
This program was done in two evenings, on the basis of MINIGRAFIK:
REM>ScreenSrc
key=&03
byte=&04
src_ptr=&05
mask_1=&FB
mask_2=&FC
dst_ptr=&FD
DIM code 4096
FOR pass=4 TO 7 STEP 3
P%=&3000:O%=code
[OPT pass
 JMP Init
 JMP Main
 JMP Kill
.Charset
 EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0
 EQUB   0:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB   0:EQUB  34:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0
 EQUB   0:EQUB  85:EQUB 119:EQUB  85:EQUB  85:EQUB 119:EQUB  85:EQUB   0
 EQUB   0:EQUB  34:EQUB  51:EQUB 102:EQUB  51:EQUB 102:EQUB  34:EQUB   0
 EQUB   0:EQUB  85:EQUB  17:EQUB  34:EQUB  34:EQUB  68:EQUB  85:EQUB   0
 EQUB   0:EQUB 102:EQUB 102:EQUB  51:EQUB 102:EQUB 102:EQUB  51:EQUB   0
 EQUB  34:EQUB  34:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0
 EQUB   0:EQUB  17:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB  17:EQUB   0
 EQUB   0:EQUB  68:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB  68:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  85:EQUB  34:EQUB  85:EQUB   0:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  34:EQUB 119:EQUB  34:EQUB   0:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB  34:EQUB  68
 EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB 119:EQUB   0:EQUB   0:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB  34:EQUB   0
 EQUB   0:EQUB  17:EQUB  17:EQUB  34:EQUB  34:EQUB  68:EQUB  68:EQUB   0
 EQUB   0:EQUB 119:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB 119:EQUB   0
 EQUB   0:EQUB  17:EQUB  17:EQUB  17:EQUB  17:EQUB  17:EQUB  17:EQUB   0
 EQUB   0:EQUB 119:EQUB  17:EQUB 119:EQUB  68:EQUB  68:EQUB 119:EQUB   0
 EQUB   0:EQUB 119:EQUB  17:EQUB 119:EQUB  17:EQUB  17:EQUB 119:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB 119:EQUB  17:EQUB  17:EQUB  17:EQUB   0
 EQUB   0:EQUB 119:EQUB  68:EQUB 119:EQUB  17:EQUB  17:EQUB 119:EQUB   0
 EQUB   0:EQUB 119:EQUB  68:EQUB 119:EQUB  85:EQUB  85:EQUB 119:EQUB   0
 EQUB   0:EQUB 119:EQUB  17:EQUB  17:EQUB  17:EQUB  17:EQUB  17:EQUB   0
 EQUB   0:EQUB 119:EQUB  85:EQUB 119:EQUB  85:EQUB  85:EQUB 119:EQUB   0
 EQUB   0:EQUB 119:EQUB  85:EQUB 119:EQUB  17:EQUB  17:EQUB 119:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  34:EQUB   0:EQUB   0:EQUB  34:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  34:EQUB   0:EQUB   0:EQUB  34:EQUB  68
 EQUB   0:EQUB   0:EQUB  17:EQUB  34:EQUB  68:EQUB  34:EQUB  17:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB 119:EQUB   0:EQUB 119:EQUB   0:EQUB   0
 EQUB   0:EQUB   0:EQUB  68:EQUB  34:EQUB  17:EQUB  34:EQUB  68:EQUB   0
 EQUB   0:EQUB  34:EQUB  85:EQUB  17:EQUB  34:EQUB   0:EQUB  34:EQUB   0
 EQUB   0:EQUB  51:EQUB  85:EQUB  85:EQUB  85:EQUB  68:EQUB  51:EQUB   0
 EQUB   0:EQUB  34:EQUB  85:EQUB  85:EQUB 119:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB 102:EQUB  85:EQUB 102:EQUB  85:EQUB  85:EQUB 102:EQUB   0
 EQUB   0:EQUB  51:EQUB  68:EQUB  68:EQUB  68:EQUB  68:EQUB  51:EQUB   0
 EQUB   0:EQUB 102:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB 102:EQUB   0
 EQUB   0:EQUB 119:EQUB  68:EQUB 102:EQUB  68:EQUB  68:EQUB 119:EQUB   0
 EQUB   0:EQUB 119:EQUB  68:EQUB 102:EQUB  68:EQUB  68:EQUB  68:EQUB   0
 EQUB   0:EQUB  51:EQUB  68:EQUB  68:EQUB  85:EQUB  85:EQUB  51:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB 119:EQUB  85:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB 119:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB 119:EQUB   0
 EQUB   0:EQUB  51:EQUB  17:EQUB  17:EQUB  17:EQUB  85:EQUB  34:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB 102:EQUB  85:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB  68:EQUB  68:EQUB  68:EQUB  68:EQUB  68:EQUB 119:EQUB   0
 EQUB   0:EQUB  85:EQUB 119:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB 102:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB  34:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB  34:EQUB   0
 EQUB   0:EQUB 102:EQUB  85:EQUB  85:EQUB 102:EQUB  68:EQUB  68:EQUB   0
 EQUB   0:EQUB  34:EQUB  85:EQUB  85:EQUB  85:EQUB 102:EQUB  51:EQUB   0
 EQUB   0:EQUB 102:EQUB  85:EQUB  85:EQUB 102:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB  51:EQUB  68:EQUB  34:EQUB  17:EQUB  17:EQUB 102:EQUB   0
 EQUB   0:EQUB 119:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB  51:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB  34:EQUB  34:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB  85:EQUB  85:EQUB 119:EQUB  85:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB  34:EQUB  85:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB  85:EQUB  85:EQUB  85:EQUB  34:EQUB  34:EQUB  34:EQUB   0
 EQUB   0:EQUB 119:EQUB  17:EQUB  34:EQUB  34:EQUB  68:EQUB 119:EQUB   0
 EQUB   0:EQUB  51:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB  51:EQUB   0
 EQUB   0:EQUB  68:EQUB  68:EQUB  34:EQUB  34:EQUB  17:EQUB  17:EQUB   0
 EQUB   0:EQUB 102:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB 102:EQUB   0
 EQUB  34:EQUB  85:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB 255
 EQUB  34:EQUB  17:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  51:EQUB  85:EQUB  85:EQUB  51:EQUB   0
 EQUB   0:EQUB  68:EQUB  68:EQUB 102:EQUB  85:EQUB  85:EQUB 102:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  51:EQUB  68:EQUB  68:EQUB  51:EQUB   0
 EQUB   0:EQUB  17:EQUB  17:EQUB  51:EQUB  85:EQUB  85:EQUB  51:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  34:EQUB  85:EQUB 102:EQUB  51:EQUB   0
 EQUB   0:EQUB  17:EQUB  34:EQUB 119:EQUB  34:EQUB  34:EQUB  34:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  51:EQUB  85:EQUB  51:EQUB  17:EQUB 102
 EQUB   0:EQUB  68:EQUB  68:EQUB 102:EQUB  85:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB  34:EQUB   0:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB   0
 EQUB   0:EQUB  34:EQUB   0:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB  68
 EQUB   0:EQUB  68:EQUB  68:EQUB  85:EQUB 102:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB  34:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  85:EQUB 119:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB 102:EQUB  85:EQUB  85:EQUB  85:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  34:EQUB  85:EQUB  85:EQUB  34:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB 102:EQUB  85:EQUB 102:EQUB  68:EQUB  68
 EQUB   0:EQUB   0:EQUB   0:EQUB  51:EQUB  85:EQUB  51:EQUB  17:EQUB  17
 EQUB   0:EQUB   0:EQUB   0:EQUB 102:EQUB  85:EQUB  68:EQUB  68:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  51:EQUB 102:EQUB  51:EQUB 102:EQUB   0
 EQUB   0:EQUB  34:EQUB  34:EQUB 119:EQUB  34:EQUB  34:EQUB  51:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  85:EQUB  85:EQUB  85:EQUB  51:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  85:EQUB  85:EQUB  34:EQUB  34:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  85:EQUB  85:EQUB 119:EQUB  85:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  85:EQUB  34:EQUB  34:EQUB  85:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  85:EQUB  85:EQUB  51:EQUB  17:EQUB 102
 EQUB   0:EQUB   0:EQUB   0:EQUB 119:EQUB  17:EQUB  34:EQUB 119:EQUB   0
 EQUB   0:EQUB  51:EQUB  34:EQUB  68:EQUB  34:EQUB  34:EQUB  51:EQUB   0
 EQUB   0:EQUB  34:EQUB  34:EQUB   0:EQUB  34:EQUB  34:EQUB  34:EQUB   0
 EQUB   0:EQUB 102:EQUB  34:EQUB  17:EQUB  34:EQUB  34:EQUB 102:EQUB   0
 EQUB   0:EQUB   0:EQUB   0:EQUB  85:EQUB 170:EQUB   0:EQUB   0:EQUB   0
.Print
 STA src_ptr:LDA #0
 ASL src_ptr:ROL A
 ASL src_ptr:ROL A
 ASL src_ptr:ROL A
 STA src_ptr+1
 CLC
 LDA src_ptr  :ADC #(Charset-32*8) MOD 256:STA src_ptr
 LDA src_ptr+1:ADC #(Charset-32*8) DIV 256:STA src_ptr+1
 JSR Address:STA mask_2:EOR #&FF:STA mask_1
 LDY #7
.Print_00
 LDA (dst_ptr),Y:AND mask_1:STA byte
 LDA (src_ptr),Y:AND mask_2:ORA byte
 STA (dst_ptr),Y:DEY:BPL Print_00
 RTS
.Invert
 JSR Address:STA mask_1
 LDY #7
.Invert_00
 LDA (dst_ptr),Y:EOR mask_1:STA (dst_ptr),Y
 DEY:BPL Invert_00
 RTS
.Address
 TXA:LSR A:TAX:PHP
 CLC
 TYA:ASL A:ASL A:ASL A:ADC Address_01,X:STA dst_ptr
 LDA #0               :ADC Address_02,X:STA dst_ptr+1
 PLP:LDA #&F0:BCC Address_00:LDA #&0F
.Address_00
 RTS
.Address_01
 EQUB &00:EQUB &C0:EQUB &80:EQUB &40
.Address_02
 EQUB &11:EQUB &11:EQUB &12:EQUB &13
 EQUB &14:EQUB &14:EQUB &15:EQUB &16
 EQUB &17:EQUB &17:EQUB &18:EQUB &19
 EQUB &1A:EQUB &1A:EQUB &1B:EQUB &1C
 EQUB &1D:EQUB &1D:EQUB &1E:EQUB &1F
.Colour
 PHP:PHA
 TXA:LSR A:STA Colour_01
 TYA:AND #&FE:ASL A:STA Colour_02:ASL A:ASL A:ADC Colour_02:ADC Colour_01:TAY
 PLA:PLP
 BCC Colour_00
 STA &9400,Y
.Colour_00
 LDA &9400,Y
 RTS
.Colour_01
 EQUB 0
.Colour_02
 EQUB 0
.Keyboard
 LDA &028D:ASL A:CMP #&08:BCC Keyboard_00:LDA #&06
.Keyboard_00
 TAX
 LDA Keyboard_05,X  :STA &F5
 LDA Keyboard_05+1,X:STA &F6
 LDY &CB:LDA (&F5),Y:TAX
 CPY &C5:BEQ Keyboard_01
 LDY #&10:STY &028C:BNE Keyboard_03
.Keyboard_01
 AND #&7F
 BIT &028A:BMI Keyboard_02:BVS Keyboard_04
 CMP #&7F :BEQ Keyboard_03
 CMP #&14 :BEQ Keyboard_02
 CMP #&20 :BEQ Keyboard_02
 CMP #&1D :BEQ Keyboard_02
 CMP #&11 :BNE Keyboard_04
.Keyboard_02
 JMP &EBA1
.Keyboard_03
 JMP &EBBA
.Keyboard_04
 JMP &EBD6
.Keyboard_05
 EQUW Keyboard_06
 EQUW Keyboard_07
 EQUW &ECE0
 EQUW &EDA3
.Keyboard_06
 EQUB &31:EQUB &33:EQUB &35:EQUB &37:EQUB &39:EQUB &2B:EQUB &5C:EQUB &14
 EQUB &60:EQUB &77:EQUB &72:EQUB &79:EQUB &69:EQUB &70:EQUB &2A:EQUB &0D
 EQUB &04:EQUB &61:EQUB &64:EQUB &67:EQUB &6A:EQUB &6C:EQUB &3B:EQUB &1D
 EQUB &03:EQUB &01:EQUB &78:EQUB &76:EQUB &6E:EQUB &2C:EQUB &2F:EQUB &11
 EQUB &20:EQUB &7A:EQUB &63:EQUB &62:EQUB &6D:EQUB &2E:EQUB &01:EQUB &85
 EQUB &02:EQUB &73:EQUB &66:EQUB &68:EQUB &6B:EQUB &3A:EQUB &3D:EQUB &86
 EQUB &71:EQUB &65:EQUB &74:EQUB &75:EQUB &6F:EQUB &40:EQUB &5E:EQUB &87
 EQUB &32:EQUB &34:EQUB &36:EQUB &38:EQUB &30:EQUB &2D:EQUB &13:EQUB &88
 EQUB &FF
.Keyboard_07
 EQUB &21:EQUB &23:EQUB &25:EQUB &27:EQUB &29:EQUB &2B:EQUB &7C:EQUB &94
 EQUB &7E:EQUB &57:EQUB &52:EQUB &59:EQUB &49:EQUB &50:EQUB &7D:EQUB &8D
 EQUB &04:EQUB &41:EQUB &44:EQUB &47:EQUB &4A:EQUB &4C:EQUB &5D:EQUB &9D
 EQUB &83:EQUB &01:EQUB &58:EQUB &56:EQUB &4E:EQUB &3C:EQUB &3F:EQUB &91
 EQUB &20:EQUB &5A:EQUB &43:EQUB &42:EQUB &4D:EQUB &3E:EQUB &01:EQUB &89
 EQUB &02:EQUB &53:EQUB &46:EQUB &48:EQUB &4B:EQUB &5B:EQUB &3D:EQUB &8A
 EQUB &51:EQUB &45:EQUB &54:EQUB &55:EQUB &4F:EQUB &7B:EQUB &5E:EQUB &8B
 EQUB &22:EQUB &24:EQUB &26:EQUB &28:EQUB &30:EQUB &5F:EQUB &93:EQUB &8C
 EQUB &FF
.IRQ
 CLD
 LDX #&00
 INC &A2:BNE IRQ_00
 INC &A1:BNE IRQ_00
 INC &A0
.IRQ_00
 LDA &A1:CMP #&1A:LDA &A0:SBC #&4F:BCC IRQ_01
 STX &A0:STX &A1:STX &A2
.IRQ_01
 LDX IRQ_03:INX:CPX #40:BCC IRQ_02:LDX #0
.IRQ_02
 STX IRQ_03:JMP &EAC2
.IRQ_03
 EQUB 0
.Norm
 LDA &900F:AND #8:BEQ Norm_00
 RTS
.Norm_00
 LDA &900F:ORA #8:STA &900F
 LDA #&00:STA &FD:TAX
 LDA #&11:STA &FE
.Norm_01
 LDA &9400,X:AND #8:BNE Norm_03
 LDY #0
.Norm_02
 LDA (&FD),Y:EOR #&FF:STA (&FD),Y
 INY:CPY #16:BNE Norm_02
.Norm_03
 CLC
 LDA &FD:ADC #&C0:STA &FD
 LDA &FE:ADC #&00:STA &FE
 CMP #&20:BCC Norm_04
 LDA &FD:SBC #&F0:STA &FD
 LDA &FE:SBC #&0E:STA &FE
.Norm_04
 INX:CPX #240:BNE Norm_01
 RTS
.Cursor
 LDX Cursor_06:LDY Cursor_07:CLC:JSR Colour:STA Cursor_08
 LDA #0:STA IRQ_03
.Cursor_00
 LDA &0286:JSR Cursor_03
.Cursor_01
 LDA IRQ_03:CMP #20:BCS Cursor_04
 JSR &FFE4:STA key:BEQ Cursor_01
.Cursor_02
 LDA Cursor_08
.Cursor_03
 LDX Cursor_06:LDY Cursor_07:SEC:JSR Colour
 LDX Cursor_06:LDY Cursor_07:JMP Invert
.Cursor_04
 JSR Cursor_02
.Cursor_05
 LDA IRQ_03:CMP #20:BCC Cursor_00
 JSR &FFE4:STA key:BEQ Cursor_05:RTS
.Cursor_06
 EQUB 0
.Cursor_07
 EQUB 0
.Cursor_08
 EQUB 0
.Right
 LDX Cursor_06:LDY Cursor_07:INX:CPX #40:BCC Right_00
 LDX #39:CPY #23:BCS Right_00:LDX #0:INY
.Right_00
 STX Cursor_06:STY Cursor_07:RTS
.Left
 LDX Cursor_06:LDY Cursor_07:DEX:CPX #40:BCC Left_00
 LDX #0:CPY #1:BCC Left_00:LDX #39:DEY
.Left_00
.Down
 LDY Cursor_07:CPY #23:BCS Down_00:INY
.Down_00
 STY Cursor_07:RTS
.Up
 LDY Cursor_07:CPY #1:BCC Up_00:DEY
.Up_00
 STY Cursor_07:RTS
.Init
 JSR Norm
 LDA #0:STA Cursor_06:STA Cursor_07
 LDA &900F:LSR A:LSR A:LSR A:LSR A:TAX:LDA Init_00,X:STA &0286
 SEI
 LDA #Keyboard MOD 256:STA &028F
 LDA #Keyboard DIV 256:STA &0290
 LDA #IRQ MOD 256:STA &0314
 LDA #IRQ DIV 256:STA &0315
 CLI
 RTS
.Init_00
 EQUB 1:EQUB 0:EQUB 1:EQUB 0:EQUB 1:EQUB 0:EQUB 1:EQUB 0
 EQUB 1:EQUB 0:EQUB 0:EQUB 0:EQUB 0:EQUB 0:EQUB 0:EQUB 0
.Main
 JSR Cursor:LDA key
 CMP #32:BCC Main_01
 CMP #127:BCS Main_01
 LDX Cursor_06:LDY Cursor_07:JSR Print
 LDA &0286:LDX Cursor_06:LDY Cursor_07:SEC:JSR Colour
 LDA &C7:BEQ Main_00
 LDX Cursor_06:LDY Cursor_07:JSR Invert
.Main_00
 JSR Right:JMP Main
.Main_01
 CMP #5  :BEQ Main_02
 CMP #18 :BEQ Main_02
 CMP #28 :BEQ Main_02
 CMP #30 :BEQ Main_02
 CMP #31 :BEQ Main_02
 CMP #144:BEQ Main_02
 CMP #146:BEQ Main_02
 CMP #156:BEQ Main_02
 CMP #158:BEQ Main_02
 CMP #159:BNE Main_03
.Main_02
 JSR &FFD2:JMP Main
.Main_03
 CMP #29 :BNE Main_04:JSR Right:JMP Main
.Main_04
 CMP #157:BNE Main_05:JSR Left :JMP Main
.Main_05
 CMP #17 :BNE Main_06:JSR Down :JMP Main
.Main_06
 CMP #145:BNE Main_07:JSR Up   :JMP Main
.Main_07
 CMP #13 :BNE Main_08:LDA #0:STA Cursor_06:JSR Down:JMP Main
.Main_08
 CMP #19 :BNE Main_09:LDA #0:STA Cursor_06:STA Cursor_07:JMP Main
.Main_09
 RTS
.Kill
 SEI
 LDA #&DC:STA &028F
 LDA #&EB:STA &0290
 LDA #&BF:STA &0314
 LDA #&EA:STA &0315
 CLI
 RTS
NEXT
FD22
Post by FD22 »
I... I don't know what to say. You passively-aggressively asked for some proof that I'm not bullshitting when I talk about something I've done that's relevant to the OP, so I showed you some real code I've written. You actually type the word 'yawn', which is just not remotely interpretable as a language/culture misalignment but is simply plain insulting.
You go on to boast that you managed to write all the (uncommented, impenetrable) code you then posted in just two nights, deriding my note about having little time to work on my project. Well, I'm really pleased for you that you live in a world where work, family life, and adult commitments don't detract from your project time.
And you then not-very-subtly imply that I could use your code as a basis for something I might be 'stuck on', even though I hadn't mentioned being stuck on anything or indeed in need of help in any way. Magnanimous, in an 'alms to the poor' way. Thanks, but no thanks.
You know what the worst thing is? You're really clever. You do stuff I find interesting, your technical posts are always the ones I look for in the Programming and Emulation threads, and on one occasion in the distant past I've even posted a question here about debugging the KERNAL to which your answer did in fact provide a vital clue that got me out of a hole. The trouble is, there's always a degree of apprehension when I click the link - will Mike just write something interesting, or will he taint it by being condescending in some way?
So, with apologies to the OP and indeed the rest of the community here for this contretemps, I'd like to make a deal with you, Mike. You refrain from commenting on my posts, and I'll do the same for you. I've desperately tried to maintain an even temper in all the threads we've co-habited, even when you've done your best to bait me, but I'm afraid you've crossed the line tonight and, whilst I'll continue to read what you write with interest, I'd prefer it if from here on we simply co-existed rather than interacted.
FD22 wrote:I... I don't know what to say. You passively-aggressively asked for some proof that I'm not bullshitting when I talk about something I've done that's relevant to the OP, so I showed you some real code I've written. You actually type the word 'yawn', which is just not remotely interpretable as a language/culture misalignment but is simply plain insulting.
Indeed, I got bored. You keep talking about your projects with no hint about when they might surface. When not too subtly hinted at that fact, you instead repeat your pattern of going personal and/or talking about language barriers.
Didn't you think posting an already-too-long snippet of boilerplate code by yourself did equally qualify as boasting?
There's a lot of side documentation for my code I didn't bother to add in. I did not expect of you, or anyone else to grasp that library code within one hour or so.
Your code also is effectively uncommented and impenetrable for anyone who is not remotely deep into the internals of the KERNAL. Cycle counts are of no relevance here. Line by line comments of assembly code don't give anything - there's no use to comment instructions with the equivalence of 'i++; // increment i'. More useful would be to add several lines of comments before each bigger block of instruction that does a coherent action.
Yet, at the end of the paragraph you again mix in your assumptions about my personal life. I won't comment further on this.
A glimpse over your blog told me otherwise. It read like a recipe to research what could go wrong. Interrupt routines hanging, a cursor leaving trails around, etc. Then, complaining about how difficult all this is. A constant urge to reinvent the wheel. Turning down offers to make this work. Not wanting to read others code. Not wanting to have to credit others for ideas taken from their code.
No wonders that gets you nowhere. When it comes to releasing working programs for the VIC-20, that is.
That was at the time you posted as MRaider here, I know. Here's the thread in question. Unfortunately, that account and all the posts of that account have been deleted, making a lot of threads incomprehensible. You stopped using that account, shortly after we had a discussion about ways of representing source code in the forum, where we couldn't get to equal terms.
Then already you resorted to personal attacks, which forced me to leave a neutral position regarding your manners. I also suspected you made it easy for yourself going against my moderation job, with you hoping the implied neutrality demanded of that moderator job might make it difficult for me to defend myself against your allegations. Well, I didn't do you the favour and instead turned down my moderator job.
When you reappeared here as FD22, it didn't take me very long to recognize you again. Yet, everyone deserves a second chance ...
I agree that the discussion at this point doesn't bring forward the original topic of the thread anymore.
Beginning with my question about the state of your project, these posts could be split into another thread.
And, I'm afraid, the easy solution you'd prefer is not going to happen. What goes around, comes around.
The VIC 20 is indeed the friendly computer! Denial strives to be an equally friendly forum. I hope all can choose to carry on with respectful and pleasant intentions. :|
