Sid Vicious - VIC 20 SID emulation
aeb
Postby aeb » Sun Dec 17, 2006 10:40 pm
I wrote a little piece of code which emulates the C-64 SID sound chip on VIC 20. Patched versions of the actual original C-64 music routines are used, only the SID part is emulated by software.
(For patching you need to change SID writes $d400-$d418 to somewhere else, like $03e0-$03f8, and check that the player doesn't overwrite any zeropage locations used by the tone generator)
Here's two examples that run on unexpanded VIC 20 (on NTSC they run a little too slow):
http://www.cncd.fi/aeeben/temp/upside.prg
http://www.cncd.fi/aeeben/temp/zoids.prg
Some sounds recorded from VICE:
http://www.cncd.fi/aeeben/temp/vic20-sid-emu-uuno.mp3
http://www.cncd.fi/aeeben/temp/vic20-si ... dedown.mp3
http://www.cncd.fi/aeeben/temp/vic20-si ... mmando.mp3
http://www.cncd.fi/aeeben/temp/vic20-sid-emu-zoids.mp3
What is emulated?
- Pulse wave (32 widths), triangle, sawtooth, noise
- ADSR envelopes, but decay and release are linear and there's only 8 volume steps
- Pitch accuracy is 1/13th of SID
- Output at 6.1 kHz, 4-bit DAC (through $900e)
The routine uses almost all rastertime (depending on playroutine used) and if there's any cycles free from NMI & IRQ, it runs in a busy loop generating random numbers to improve the noise emulation.
Here's how it's done:
http://www.cncd.fi/aeeben/temp/sidemu_source_v0.zip
This is still very much work in progress, for example most of the patching could be automated. SID players that are located below VIC 20 ROM's need to be relocated, which is a bit more work.
Have fun!
Postby carlsson » Mon Dec 18, 2006 2:18 am
Ah, so it generates a three note sample on the fly? Cool, along with what you'd expect from Aleksi.. Is the Polytracker also feasible to convert, or does it use too much RAM for samples?
GreyGhost
Postby GreyGhost » Mon Dec 18, 2006 9:15 am
very cool
Rob
vic user
VicGyver
Postby vic user » Mon Dec 18, 2006 9:42 am
wow, is "upside down" ever well done!
adam.klotblixt
Postby adam.klotblixt » Sat Dec 30, 2006 3:30 pm
Very nice indeed!
I like the Zoids clip, very close to the real thing.
I gather you use the wla_dx assembler?
/Adam
Victragic
Frogger '07
Amazing
Postby Victragic » Sat Jan 06, 2007 1:17 am
This is exactly the sort of project I was hoping to find someone working on in rediscovering my interest in VIC 20s recently..
It's a very impressive result, and I'll say the 'Commando' soundtrack is spot on as well..
I guess it's possible to get the valiant VIC-I to emulate anything.. (but obviously not everything at the same time!)
Excellent work!
-G
Jaicen
Postby Jaicen » Sat Jan 06, 2007 6:34 am
Wow that's brilliant!
Seriously, Upside Down is fantastic! Great work for sure. Could it be applied to run sampled music during games? Though you mention it eats up most of the raster time, so i'm guessing that's a no?
Postby Jeff-20 » Sat Jan 06, 2007 2:06 pm
Goodness! Amazing!
aneurysm
not your PAL
Postby aneurysm » Sun Jan 07, 2007 7:19 pm
\o/
too bad i know nothing about cross-platform development
Jaicen
Postby Jaicen » Mon Jan 08, 2007 4:54 am
You know how to rock a tasty jam tho ;)
Postby ral-clan » Mon Jan 08, 2007 6:36 am
The idea of emulating a SID on a VIC (and the fact that it can actually be done) is one of the most incredible things I've seen lately (and I've seen a lot of amazing VIC-20 things since joining DENIAL). 8)
blackystardust
Postby blackystardust » Sun Jul 08, 2007 10:14 am
I know it has been a while since this topic first appeared, but I just got wind of it now. I can't seem to be able to download any of the files, does anyone else still have them or has an alternate link to them.
Boray
Musical Smurf
Postby Boray » Sun Jul 08, 2007 11:47 am
Seems I missed this thread too...
Wonder-Boy
Postby Wonder-Boy » Thu Jul 12, 2007 9:50 am
@blackystardust
I can download them
Boray
Musical Smurf
Postby Boray » Thu Jul 12, 2007 10:15 am
I can't
Return to “Programming”
Who is online
