VIC-20 Software Releases of 2014
Name: BASIC ROM patch
Author: Mike
Released: Januar 1st, 2014
Requirements: VIC-20
Description: a firmware patch to cure a defect in the multiplication routine of the BASIC ROM
Screenshot (try it out with an unpatched ROM!):
Download: basic-patch.prg
Read more and discuss the release here (software) and here (hardware).
Re: VIC-20 Software Releases of 2014
Name: Realms of Quest IV (Official Release)
Author: Ghislain
Released by Psytronik on: January 19, 2014
Requirements: 16K/24K VIC-20 (for Realms IV), Unexpanded VIC-20 (for Realms I+II) and Commodore 64 (for Ultimate Quest: Catacomb). A disk drive is also required.
The adventure continues in Realms of Quest IV where you assemble a group of heroes to do battle against the mysterious Time Lords inside the Dungeon. Thus befalls you, brave adventurer, to accept the challenge and venture forth into the labyrinth below to ensure that evil and chaos do not rise. If you can survive the perils that await beneath, there lay riches, glory and the immortality of your name.
Realms of Quest IV Features:
• 10 Dungeon Levels which have been designed by hand with numerous rooms, secret passages, riddles and traps to traverse and overcome.
• 10 races and 12 classes to choose from to create 8 players for your party.
• You will meet other heroes to help and guide you during your quest.
• Over 100 unique graphical portraits that depict the various monsters that you'll encounter as you travel throughout the Dungeon.
• Over 135 types of equipment to represent weapons, armor, gems, jewelry, potions, scrolls and miscellaneous magical items.
• 60 magic spells that you can cast.
• 3 game fonts to choose from.
• A 16 page printed instruction manual is also included.
All of this for your Commodore VIC-20, a disk drive and 16K of expansion memory. 24K is recommended as it features reduced disk loading times, an improved 3D graphical perspective and game music.
Side two features the Special Anniversary Editions of Realms of Quest I & II for the Unexpanded VIC-20. Also featured is the long-awaited Ultimate Quest: Catacomb for the Commodore 64 - originally created in 1989, now finally completed.
To buy a physical copy of the game on disk and a 16 page printed instruction manual in it's very own plastic jewel case, go here http://www.binaryzone.org/retrostore/in ... cts_id=631
Go here to get a lower-priced budget disk-only version http://www.binaryzone.org/retrostore/in ... cts_id=632
You can also obtain a digital copy of the game here http://www.binaryzone.org/retrostore/in ... cts_id=633
Discuss here http://sleepingelephant.com/ipw-web/bul ... =10&t=6350
Name: MG Text Edit
Author: Mike
Released: February 3rd, 2014
Requirements: VIC-20 with +8K RAM expansion
Description: Text screen designer for MINIGRAFIK bitmaps
Download: mg_text_edit.zip
Read more and discuss MG Text Edit here.
bills442
Post by bills442 »
Authors: Dane Bills, Jeff Messner
Released: March 2, 2014
Requirements: VIC20 with +3k or +8k, joystick ( developed on NTSC)
Description: A maze game clone of a well known 80s game written in assembly
ScreenShot:
Release Notes: 3/5/2014: change start address so you can load with just ,8. Locked the framerate to 30fps. This fixes the jumpy behavior on PAL.
Video of first test: http://www.youtube.com/watch?v=MKnd8T4pi18
Both versions should load and you can type 'run' from the basic prompt after loading.
e.g.: load "panicman3k.prg",8
There is no difference between the 3k and 8k version other than a splash screen to show the authors on the 8k. I just thought it might be nice to have the 8k executable for someone to run on the real iron if they didn't have a 3k cartridge. The 3K has received the most testing on real hardware.
+3k version:
https://drive.google.com/file/d/0B0VOPY ... sp=sharing
+8k version
discussion thread: http://sleepingelephant.com/ipw-web/bul ... =10&t=6870
Misfit
Post by Misfit »
Author: Misfit
Released: 06.03.2014
Requirements: Unexpanded VIC-20 + Joystick.
Description: A stupid Flappy Bird clone for VIC
Tested : VICE 2.4 and real VIC (PAL)
Download : PRG
Discuss here
Website: http://hugbox.org/
Author: pixel
Released: March 8th, 2014
Last update: November 26th, 2015
Description: A horizontally smooth-scrolling shoot-'em-up, heavily inspired by the classic arcade game "Gradius";
PRG file: http://hugbox.org/pixel/external/pulse.prg
Binary for Raspian on Raspberry Pi: http://hugbox.org/pixel/external/denial ... pberry.bin
Source code: https://github.com/SvenMichaelKlose/pulse (excluding tape release version)
Denial thread: http://sleepingelephant.com/ipw-web/bul ... =10&t=6868
pouet.net entry: http://www.pouet.net/prod.php?which=62730
Peter
Post by Peter »
Name: Get the Cat
Author: Peter van der Woude
Released: August 7, 2014 (final version)
Requirements: Unexpanded VIC-20 (joystick required)
Description: A simple game: Step on the blocks to save your cat.
download link: https://drive.google.com/file/d/0B6lVWB ... sp=sharing
Instructions: move left and right with the joystick. Press fire to place a block under your character, provided you have blocks left. Your character can step up one block only. You can let him fall from any height. The blocks fall randomly. Every fourth block falls directly above you, use it to your advantage. If you reach level 5,10,15,... you gain an extra live. Select normal or endless option. Choose Endless and you don’t lose lives, but no highscore is set.
Thread: http://sleepingelephant.com/ipw-web/bul ... =10&t=6942
Author: tokra
Released: Apr 17, 2014 (bug-fixed PAL-version Apr 23, 2014)
Requirements: NTSC VIC-20 with 32K RAM expansion and/or PAL VIC-20 with 24K RAM expansion
Description: Slideshows for two newly created VIC-20 graphic modes:
for NTSC-VIC 20: IFLI88 (88 x 400 interlace with 8 x 1 color res)
for PAL-VIC 20: FLI104 (104 x 256 with 8 x 1 color res)
Download: http://www.tokra.de/vic/flinale/flinale.zip
NTSC YouTube
PAL YouTube
pouet.net-Entry
NTSC-Discussion HERE
PAL-Discussion HERE
Misfit
Post by Misfit »
Name: Bertie The Ball
Author: Misfit
Released: 16.04.2014
Requirements: 16k VIC-20 + Joystick.
Description: an action-adventure / platformer for 16k VIC-20 computer. It's a tribute to the great C64 game called "Cauldron II: The Pumpkin Strikes Back"
Download : PRG
Video : youtube
joystick up or fire = jump
left or right = move
down = fast landing, balancing
discussion thread
Schlowski
NoMess!
Post by Schlowski »
Author: Schlowski
Released: 22.04.2014
Description: A clone of iOS Threes for VIC
Tested : VICE 2.4
Download : http://www.stojalowski.de/files/threes.prg
Discuss here:http://sleepingelephant.com/ipw-web/bul ... =10&t=6949
Name: FIFA World Cup 2014
Author: Jeff-20
Released: June 2, 2014
Requirements: VIC-20 (no memory expansion required), keyboard controlled
Description: A simple, arcade style soccer/football game.
- all 32 participating national teams
- one player elimination mode ("knockout rounds")
- two player vs mode
- adjustable skill levels
Download: DOWNLOAD
You can discuss FIFA World Cup 2014 here.
Name: Ice Hockey 2014
Author: Jeff-20
Description: Essentially, a variation of World Cup 2014. A simple, arcade style hockey game.
- all 16 participating national teams in IIHF Championship
- all 30 NHL hockey teams with two defunct teams for added measure
Download: DOWNLOAD
You can discuss Ice Hockey 2014 here.
Author: viznut/pwp
Released: August 2nd, 2014 (Assembly '14 Real wild demo compo)
Requirements: unexpanded VIC-20 (PAL)
Description: Demo
Download: pwp-warning.zip
Read more and discuss 'Warning' here.
Shaun.Bebbington
Post by Shaun.Bebbington »
Name: Minesweep Mini (aka Minesweeper Mini)
Author: Donkeysoft
Released: October 8th, 2014
Description: Cost-reduced Mine Sweeper game in CBM BASIC
Download: mine-sweep-mini.zip
Read more and discuss 'Mine Sweep Mini' here.
Without context, we are only data.
Shaun.Bebbington
Author: Donkeysoft
Released: October 25th, 2014
Description: Bounce the ball against the walls and ceiling
Download: See attached
Read more and discuss 'Bounce' here.
bounce.zip
Bounce Freeware
(1.44 KiB) Downloaded 538 times
